Results 1 to 10 of 10
    Greene, Iowa
    3 (100%)
    99 Chevrolet Camaro Z-28
    Pair of 02 simulators/extensions
    like title mentions im looking for a pair of 02 simulators, and extensions. im gonna dive into a lt header install, so im gathering all my needed parts.. so if you have these mentioned parts, let me know. thanks in advance
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Why not pick up a pair of Bosch 13111 O2 sensors? - you'll be better off. The O2 sims are known to cause problems with our cars. The extensions too. If it's for the rear O2s - you can just have them tuned out. Our cars require the front ones for the proper A/F ratio.
    Greene, Iowa
    3 (100%)
    ill eventually have the rears tuned out. but want to get everything i want done to the car first so when i mail my ecu out to get tuned itll be done all at once, vs, paying 125 every time i make a change to the car, so ill need to run some sims for a while till i get all my stuff done
    Greene, Iowa
    3 (100%)
    oh wait. id need the extensions if i were running rear 02's.....well scratch the extensions all ill need is the sims
    99 WS.6 - Modified
    If you replace the front ones with the Boschs, and just disconnect the rears, you can run the car fine until you get it tuned. The rears will just bring the ses light on, they will not affect performance - as they only tell the car if the cats are functioning properly.
    Greene, Iowa
    3 (100%)
    why would i need to replace the fronts?
    99 WS.6 - Modified
    When you install the LTs the wire harnesses for the front ones will not be long enough. This is why many just install the 13111s - as they come with a longer wiring harness. You can buy extensions and use your existing O2s, but many have had problems with them - I would imagine because of the added connections and more opportunites for a bad connection.
    Greene, Iowa
    3 (100%)
    ok..im not spending 100 bucks per sensor, so im looking for o2 extensions still along with sims
    99 WS.6 - Modified
    $100 per sensor? They only run about $57 or so each depending on where you get them from. Summit even carries them for around $69 I think. You'd end up paying about the same for the sims and extensions, but if that is the way you want to go, I'm sure someone will post some up for you soon.
    Next... MrKid's Avatar
    Sep 2009
    Milford, CT
    3 (100%)
    '68 Camaro RS, '11 Camaro
    I have enxtensions I never used if interested. They are the better style with actual heat wrap instead of tubing. $30 shipped.
  1. O2 simulators?
    By SS-Power in forum Computer & Tuning
    Last Post: 10-09-2008, 08:10 PM
  2. O2 simulators?
    By tav8ws6 in forum External Engine
    Last Post: 04-07-2007, 07:47 AM
  3. WTB- o2 simulators
    By drb131s in forum Parts Wanted / Trade
    Last Post: 09-17-2006, 04:18 PM
  4. O2 Simulators and Extensions
    By navy02ws6 in forum Parts For Sale / Trade
    Last Post: 08-24-2006, 01:03 PM
  5. o2 simulators
    By MCCs WS6 in forum External Engine
    Last Post: 04-11-2006, 11:48 AM
