Thread: O2 simulators?
10-02-2008, 03:01 PM #1
O2 simulators?
I just install O2 simulators for my car. I was hoping this will turn off my service engine light. The light came on when I installed my headers. Anyone know how soon the light will go off? I'm hope soon, because my inspection is up.
10-02-2008, 03:15 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
You can reset the PCM manually to clear codes, but I wouldn't do that if your inspection is an OBDII check and due immediately - it'll also reset all your readiness tests. You can look up the codes and see how many cycles it takes to turn them off at gearchatter.com or just do some drivecycles like suggested at www.obdii.com/drivecycle.html If you know someone with a scan tool you could have them just clear the codes.
10-02-2008, 03:32 PM #3
10-02-2008, 08:53 PM #4
10-03-2008, 09:51 AM #5
also, is the light for the cats only? did you remove the AIR system as well? when you do a MIL light reset, the PCM stores when you did that. some of the readiness tests will not be complete for at least 50 miles.
10-05-2008, 12:28 PM #6
What code/codes are displayed. I read that you just installed headers. Are they LT's? If your O2 sensors arent up to snuff they could be reading lazy now. If the code was for the rear sensors then after 3 normal drive cycles the code will shut off if the rear O2 sims are functioning properly.
10-09-2008, 09:10 PM #7Junior Member
- Aug 2008
- conneticut
red- 2002 35th anniversary
you need to find out what codes you have before you do anything.putting on headers shouldn't give you a lite.ck all the wiring and plugs to make sure they are connected good and clean and the wire are not hitting the headers.i melted a harness on my headers.i have had simular problems with my 02 35th.i removed my syms and it got rid of the lite but im still getting codes 1133/0155.get them cleared after you find out whats wrong.don't do a complte scan because it erases the computer and you won't pass emmissions.
o2 simulators
By supercampeones4 in forum Computer & TuningReplies: 3Last Post: 12-01-2010, 09:36 AM -
02 simulators?
By mears_ls1 in forum External EngineReplies: 2Last Post: 10-21-2010, 01:06 PM -
Question: 02 simulators
By formula1804 in forum General HelpReplies: 7Last Post: 05-10-2009, 07:06 PM -
o2 simulators
By BirdCountry02 in forum General HelpReplies: 19Last Post: 03-15-2009, 09:16 AM -
EGR Simulators?
By ~Firehawk~ in forum GM TrucksReplies: 0Last Post: 10-03-2005, 06:13 PM
