Results 1 to 1 of 1
06-03-2010, 01:20 PM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
GM's Variable Valve Timing System Performance Test
GM's Variable Valve Timing System Performance Test - 15 Degrees Of Separation - Speed Parts Testing
The tough guy in you says to stab that cam in retarded a few degrees for maximum top-end horsepower, while your more practical alter ego suggests advancing it a hair for improved low-end torque and driveability.The tough guy in you says to stab that cam in retarded a few degrees for maximum top-end horsepower, while your more practical alter ego suggests advancing it a hair for improved low-end torque and driveability. As tempting as it may be to let your tough side deliver a swift kick to your practical side's shins, the installed centerline you settle on is often a compromise between the two extremes. However, as the Big Three have started integrating variable valve timing (VVT) into production V-8s, that needn't be the case anymore. Now you can have the best of both worlds.
Photo Gallery: GM's Variable Valve Timing System Performance Test - Hot Rod Magazine
More...
D-Port Head Valve Upgrade - Big-Valve Performance on a Small
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 04-20-2011, 04:10 PM -
Performance Valve Job - Valve Job Victory
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 04-04-2011, 08:40 AM -
Valve cover gaskets, Valve Springs, Timing Gasket
By Dewman in forum Parts For Sale / TradeReplies: 0Last Post: 01-22-2010, 08:14 PM -
Variable Valve Timing - The Next Phase
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 07-21-2009, 08:50 PM -
For Sale:L92 timing chain, oil pump , push rods, valve springs
By sickspd in forum Parts For Sale / TradeReplies: 2Last Post: 04-17-2007, 04:53 AM
