Results 1 to 1 of 1
07-21-2009, 08:50 PM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Variable Valve Timing - The Next Phase
Nearly every new engine coming out of Detroit has variable valve timing. Here's what it is and how to deal with it.Once upon a time, picking a cam for a given engine combo was all about compromise: improve top-end power at the expense of low-end torque, run well at wide-open throttle but sacrifice idle stability and part-throttle cruise driveability, trade off performance for gas mileage, run hard or run clean. Thanks to OEM-developed variable valve timing (VVT), it doesn't have to be that way anymore.
Photo Gallery: Variable Valve Timing - VVT For Performance Applications Explained - Hot Rod Magazine
More...
GM's Variable Valve Timing System Performance Test
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 06-03-2010, 01:20 PM -
Valve cover gaskets, Valve Springs, Timing Gasket
By Dewman in forum Parts For Sale / TradeReplies: 0Last Post: 01-22-2010, 08:14 PM -
center bolt valve covers, timing, valley and rear covers
By jjz28 in forum Parts For Sale / TradeReplies: 0Last Post: 09-05-2007, 12:14 PM -
center bolt valve covers,timing,valley and rear covers,crank
By jjz28 in forum Parts For Sale / TradeReplies: 2Last Post: 08-12-2007, 05:10 PM -
For Sale:L92 timing chain, oil pump , push rods, valve springs
By sickspd in forum Parts For Sale / TradeReplies: 2Last Post: 04-17-2007, 04:53 AM
