Page 1 of 3 123 LastLast
Results 1 to 20 of 54
    Senior Member NeeD4SpeeD's Avatar
    New York, NY
    Collectors Edition Yellow
    2002 Pontiac Trans AM WS6
    Exclamation BEST Heads for the $$??
    I just finished up my cam install and put down some nice numbers (in sig) now looking for a nice set of heads.. I was thinking about the New Patriots that came out but wasn't sure if they were the "best bang for the buck".. I am planning on milling the heads also and port matching with my 90mm FAST intake....Which heads do you think are the best????
    Bulletproof Performance
    2002 Trans AM WS6 M6 Collectors Edition
    LSX 427 F-1R Procharged Build Underway
    Estimated Finish Date: Summer 2012-2013
    BLOWN_70_CAMARO
    Guest
    My buddy keeps talking about the AFR heads. but knowing that Dart has a new set out and for $1,600 assembled up to an .625 lift cam. thats the way i would go
    New York, NY
    I like the afr heads..but i'm not paying $2300 for the same performance i can get from a $1200 patriot.... Are the darts good??? Not made shitty are they? I want to make the max power with out maxin my wallet out
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    patriot 2.5s
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Fort Worth, Tx
    2001 Formula Firebird
    No offense to Patriot, but I just don't think that they are the best flowing head out there.... although they may be the cheapest. If you have the cash to go with something like AFR, I would do it.
    Awaiting Activation Liquifire's Avatar
    central wisconsin
    Quote Originally Posted by NeeD4SpeeD
    what size cam?
    Bowman, SC
    Crytal Red Tint Coat
    2013 SS Camaro Covertible
    Check out the new Racing Head Service Heads! Hear is a link.
    http://www.racingheadservice.com/Pro...ds/PE-GIII.asp
    2013 Camaro SS Convertible, Whipple Supercharger, Kooks Coated 1 7/8" headers, CAI Cold air induction
    http://s33.photobucket.com/user/Deea...?sort=3&page=1
    New York, NY
    Quote Originally Posted by Liquifire
    what size cam?
    The cam is a TR 232/237 .595/.605 112LSA....pretty big so i want nice heads to help with flow...
    New York, NY
    Quote Originally Posted by FunkyTownFBody
    I dunno man...alot of people on here sware by patriot performance... I heard their now LS6 heads 205cc were very good if not better then afr.... I'm not claiming they are this is just what i've heard from numerious people....
    Also 1 guy told me that with 2 seperate dyno runs and 1 with the afr 204 and the other with the pat 205 the pat actually added 9hp more then the afr...Duuno if its true or not but this is what he told me....
    New York, NY
    Also 1 guy told me that with 2 seperate dyno runs and 1 with the afr 205 and the other with the pat 205 the pat actually added 9hp more then the afr...Duuno if its true or not but this is what he told me....
    Junior Member g.t.o.boy's Avatar
    Littleton, CO
    Nassau Blue
    1999 FRC Corvette
    Buy the patroits and use the left over money for a 12 bolt rear, you are just paying for afr's R and D.
    Littleton, CO
    Nassau Blue
    1999 FRC Corvette
    Member wesTXwitesnake05's Avatar
    Feb 2006
    Midland TX
    White with silver stripes
    2000 Trans Am WS6
    Patriot's heads are by far the best bang for the buck ls-series heads out there. i got a set of NEW stg II ls6, assembled with dual valve springs and upgraded valves for $980 on ebay. they flow great, 304 cfm @ .600 lift intake and 229 @ .600 ex. best $980 i ever spent!
    Dec 2002
    n/w chicago
    if you want to pay almost double for a set of heads that make around 10 more horsepower, go for it.
    Feb 2006
    California
    98 Trans Am
    Quote Originally Posted by wesTXwitesnake05
    I went with the Patriot stage II LS6 style heads also. It's hard to beat $1,275 for the heads with gaskets and head bolts. I couldn't justify paying twice that for AFR's, and a LITTLE extra power.
    Feb 2006
    australia
    03 vy2 holden ls1 ute
    hhmmm a hard choice afr or paitroits either will work fine imho
    Feb 2006
    Midland TX
    2000 Trans Am WS6
    if you got the cash go with afr but for the price of the afr's u could get patriot's heads and a good set of shaft mounted rockers, and probably still have some change
    Pueblo, Colorado
    1998 Pontiac Trans Am
    Don't rule out PRC heads either. Last time I checked they were decently priced. Although I think their stage 2.5 ls6 heads are a bit pricey their stage 1 ls6 heads and stage 1/2.5 5.3l heads are pretty cheap.
    Feb 2006
    California
    98 Trans Am
    Quote Originally Posted by ~redlinels1~
    Prc has some heads for $899 I believe, but they come with the early LS6 springs. Unless you have a baby cam, you'll have to swap out the springs and then you pay as much as the Patriots, which come with head gaskets and bolts. If you do have a small cam then you probably don't want the PRC's anyways, as they have 237 cc intake runners. With runner volume like that, I don't think I'd buy the PRC's unless I was using a big/high lift cam.
    ls1tech director
    Santa Clarita, CA
    laser red
    1994 Mustang GT
    theres some uneducated people when it comes to heads in this thread...
  1. Replies: 0
    Last Post: 03-16-2011, 09:30 AM
  2. Replies: 0
    Last Post: 02-04-2011, 02:00 PM
  3. AFR heads VS. Ported and beefed up stock heads.
    By hutcher04 in forum Internal Engine
    Last Post: 03-14-2010, 08:27 AM
  4. New Heads or Port/Polish Stock Heads?
    By Black02LS1 in forum Internal Engine
    Last Post: 06-22-2007, 11:29 PM
