    Junior Member BallerDave's Avatar
    Tracy, CA
    Bright Rally Red
    2002 Camaro Z28
    spark plug threads trashed
    Got an 02 Z28, the #1 cylinder spark plug threads are damaged. Can it be repaired or do I need a new head?
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    They make thread chasers to repair the threads. One company actually makes a tool that expands after you put it in the hole. It will rethread from the inside out. Also make sure you use some grease to hold the metal shavings.
    Tracy, CA
    Bright Rally Red
    2002 Camaro Z28
    I've heard there are ways to fix it. Some people say the head has to come off, others don't.
    East of Cleveland, Ohio
    99 WS.6 - Modified
    It really depends on how bad they are damaged. If not too bad you might just be able to use a tap to straighten out/clean up the threads. If pretty bad, you may be able to use one of the tools that BigRon mentioned. Worse case, you could take the head off and take it to a shop to repair. That would also be a good time to look into upgrading if you're still stock.
    well, number 1 gives you about the most room out of all of them to work on the car. Might have to put a heli-coil in there to fix it. I would look at running a tap first and see if you can straighten those threads out.
    Tracy, CA
    Bright Rally Red
    2002 Camaro Z28
    that's what I was thinking. If the heads come off replace them with something better. Being an 02 it already has LS6 block/intake. Might as well add the heads and cam.
  1. Oil On My Spark Plug Threads (not tips)
    By Naaman in forum Internal Engine
    Last Post: 01-05-2012, 12:53 PM
  2. spark plug threads stuck in hole
    By ls1wallen in forum General Help
    Last Post: 05-23-2011, 10:36 AM
  3. What kind of oil 5w30& spark plugs&spark plug wire
    By ROMERO98Z28 in forum General Help
    Last Post: 09-01-2009, 01:50 PM
  4. Spark plug wire and plug!
    By RYDER661 in forum General Help
    Last Post: 03-13-2006, 09:01 PM
