Results 1 to 15 of 15
Thread: Third Gens
    Member 1998 T/A's Avatar
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    Third Gens
    may pick up a third gen camaro this summer...the point is i know that they run about 200hp stock, give or take a few. My question is what should i add to get more hp and tq out of these cars. i know emissions cotrols took a toll on the output for these cars...suggestions and or expected power output? ty
    Nov 2008
    harrisburg pa.
    02 vette vert
    crate motor.
    Are you against a motor swap? Possibly an LSx motor swap?
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    tryin to keep it cheap...theres a local kid sellin a 92 with the 305 in it, automatic...it needs a couple grand in body work so i dunno, kind of would like to keep the 305, maybe get some bored out heads and do full bolt ons
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by 1998 T/A View Post
    imho 305 is'nt worth your time. Get a 4-bolt 350 and go from there. Have to make it breath to get to a chevys power.
    Senior Member big hammer's Avatar
    manitoba, canada
    2002 ws6
    dont even need a 4 bolt. a 2 bolt is easily capable of 400hp. some people even go as far to say that 4 bolts are weaker due to the extra holes in the main webbing.
    i ran 600+ hp on a 2 bolt 400, stock crank and rods but studded. take it form me, no matter what you build, stud the bottom end! a couple hundred bucks could save you thousands!
    Pittsburgh
    2008 Hummer H3
    I prolly should'nt have said the 305 is'nt worth your time. My bad.... Because I get heckled about liking v6's.. Build what you like. There's always forced induction. Or even spray it..
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by big hammer View Post
    I'd put a 4bolt 350 sbc against a 2 bolt 350 any day..
    manitoba, canada
    2002 ws6
    you're right though--- if you're building, a 305 isnt worth your time. but if it's in there and a strong engine, a simple cam, carb intake and header will make it twice the engine.
    manitoba, canada
    2002 ws6
    i've built both, and wouldn't build a 350 again. too small.
    i've never had a crank\rod failure with either anyway.
    Pittsburgh
    2008 Hummer H3
    agree
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    ya its just the way its going right now with work i dont think im going be able to afford another LS1 this summer. i had a third gen v6 in high school and i like those body styles so just trying to find the fastest way to get behind another muscle car. i'll keep my eyes open for a 350 but who knows
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    The small bore of the 305 tends to shroud valves. And the 305 swirl port heads are basically junk. The LO3 engines (TBI type - looks kinda like a carb) put out only 170hp.
    If you can find one put a worked over 400 in it. That with the TPI setup and some gears will give you an easy 12 second ride.
    manitoba, canada
    2002 ws6
    Quote Originally Posted by 67CamaroRSSS View Post
    yeah swirl port heads aren not for hp--- they're for low end torque. i like the way they act in my 89 chev, but not for a car.
    i love 400 sb's though! good power for cheap.
    Pittsburgh
    2008 Hummer H3
    Wink
    Which is about 10hp more than a single cam 3.4L v6. and 30-45hp less than the tdc 3.4L w body which will eat a 305.. 30 less than the 3800II.. 305 is about twice as heavy as the 207's. But to each thier own. I would'nt muk with a 305 but then again not many folks here like to muk with v6's either.. Even with headers and a cai, only going to see stock 3800II power levels.. Just my .02..
  1. BCM, Are the Universal with 4th GENs?
    By SMWS6TA in forum General Help
    Last Post: 03-01-2011, 06:05 PM
  2. BCM, Are the Universal Between 4th GENS?
    By SMWS6TA in forum Parts For Sale / Trade
    Last Post: 03-01-2011, 03:58 PM
  3. 20's on 4th Gens ?
    By WhatUpWhatUp in forum Camaro / SS
    Last Post: 11-02-2010, 08:08 AM
  4. Will our 4th gens be the "3rd gens" of 2009?
    Last Post: 02-19-2007, 07:16 PM
  5. 10' sub box for 4th gens
    By PARTSMAN84 in forum Parts For Sale / Trade
    Last Post: 10-27-2006, 04:31 PM
