Results 1 to 20 of 20
Thread: Many water spots on glass
05-17-2010, 06:31 PM #1
I have owned dozens of cars and have never seen water spots like on my T/A. They are on all of the glass, tried aerosol and liquid glass cleaner as well at glass wax.
Any ideas?
05-17-2010, 07:23 PM #2
Have you tried 0000 steel wool? Hard water scale build up is a common problem in Florida. It's going to take a ton of elbow grease to get it all. Perhaps someone will chime in with a product they've used.
05-17-2010, 08:31 PM #3Electrical Engineer
- Jul 2009
- North of the Motorcity
Your not doing this while in the sun, right?
Rain-x has a new "deep clean" product you could try. It seems to have alittle bit of a "grit" to it. But as stated b4, elbow grease might be the best product.
You could try some rubbing alcohol. When ever I get nasty tree sap all over the DD's windshield, that's the only thing I have that will take it off.
05-17-2010, 08:40 PM #4
This is talking about water scaling on shower doors, but same principle.
I've also read that 2 parts white vinegar to 1 part distilled water with elbow grease.To remove water scale, you can enlist the help of a variety of different industrial acids, including sulfuric acid, phosphoric acid, glycine acid, and barium nitrate. These cleaners help remove water scale by breaking down the deposits left on your shower. You can also remove water scale with the assistance of high pressure steaming, which causes the water scale to loosen and fall off.Last edited by tpilews; 05-17-2010 at 08:43 PM.
05-17-2010, 08:40 PM #5
A mixture of two parts white vinegar to 1 part water and rubbed out with cheesecloth may do the trick.
05-17-2010, 08:45 PM #6
05-17-2010, 08:48 PM #7
05-17-2010, 08:58 PM #8
05-17-2010, 09:01 PM #9
05-17-2010, 09:03 PM #10
05-17-2010, 09:14 PM #11Just me
- Nov 2006
- Broken Arrow, OK
Vinegar and the steel wool would both work.
05-17-2010, 09:18 PM #12
05-18-2010, 06:41 PM #13Awaiting Activation
- Apr 2006
- Grandville, MI
Red Jewell Tintcoat- 2008 Grand Prix GXP
Claybar the windshield 1st. After that use 3M Adhesive and wax remover and use a razor
on any of the areas left affected.
05-19-2010, 01:11 PM #14
05-19-2010, 03:06 PM #15Awaiting Activation
- Oct 2008
- Pa
Blue- 2000 TA
Zaino glass polish and a PC, Duragloss water spot remover after each wash.
05-19-2010, 06:58 PM #16
05-20-2010, 11:11 AM #17Senior Member
- Jan 2010
- texas
silver- 2000 formula
rain X is a great glass cleaner......as well as a rain repellant
05-22-2010, 08:54 AM #18Junior Member
- Sep 2009
- Floriduh
BGC- 2001 Formula
I use 0000 steel wool with Weiman glass cook top cleaner and a little water.
it does a great job of cleaning the windshield of water spots and you can get it cheap, the bottle will last a long time.
the steel wool is around $3.00 and I think the cleaner was under $4.00, you can buy everything at walmart the cleaner is with the household cleaners and steel wool in the paint dept.
I do my windshields in a 2' x 2' section at a time and rinse, stubborn waterspots come right off.
hope this helps
Bill
06-18-2010, 01:12 PM #19Junior Member
- May 2010
- Rifa' Ash Sharqi, Al Rifa` Wa
Black- 2001 Z28
I bought my car 2 weeks ago and the glass is covered in water spots. I wish i looked on here first and tried the vinegar but i found that the red Turtle Wax rubbing compound worked great. You really have to rub but it does the trick and doesnt scratch the glass. I'll try the vinegar solution on the back window tomorrow.
Here is what the water spots on my windows looked like and what the rear window still looks like...
06-20-2010, 09:32 PM #20
Google griots garage they sell a glass cleaner you can use on a orbital buffer and it worked on my TA. The actually sell a package with a 3" buffer and glass cleaner that's not much if you don't have a buffer.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
Got bad hardwater spots on exterior glass? tried n true
By Questioner in forum Showcar and DetailingReplies: 4Last Post: 10-02-2014, 10:52 AM -
Water Spots
By jcneef in forum Showcar and DetailingReplies: 2Last Post: 03-23-2011, 08:12 AM -
water spots !!!
By WetSpot in forum Showcar and DetailingReplies: 14Last Post: 01-21-2009, 07:53 PM -
F'ing water spots!!!!!
By third_shift|studios in forum Showcar and DetailingReplies: 37Last Post: 10-08-2007, 07:04 PM
omg, my ears just imploded thinking about what that must sound like
