Thread: ls6 intake manifold
05-07-2010, 12:27 PM #1
ls6 intake manifold
i am going to swap the stock intake off of my 99 z to an ls6 intake, just trying to make sure it will be a direct replacement or if i am going to need any parts, also will it run ok without a tune????
05-07-2010, 12:38 PM #2
talk to vertiviper, he just did a complete swap with pictures.
05-07-2010, 12:50 PM #3
The only additional parts you will need is a coolant bypass. When you take off the LS1 manifold you'll see coolant lines running from the back of the block to the front and into the TB, the rear lines get plugged and the front remain.
It's not a tought job, just take your time, look up "how to" there are tons of them.
And everyone will tell you to be carefull to not break the oil pressure sending unit behind. If you can reach behind and unclip the wire to it you'll save urself loads of headaches trying to fish the brake booster hose through there.
05-07-2010, 12:59 PM #4
one more question, does the ls6 intake really make that big of a difference?
05-07-2010, 01:59 PM #5Senior Member
- Nov 2006
- Indianapolis
^^^from what I've read here, everyone who has done the swap says it is well worth it.
They said it really wakes up above ~4,000 RPM, but not much change below that. Probably good for ~10 HP.
05-07-2010, 02:17 PM #6
05-07-2010, 03:05 PM #7Member
- Jun 2009
- coon rapids, MN
red- 2000TA
you can retain the stock ls1 coolant lines,care fully remove some of the ribbing on the under side of the ls6 intake.you can do a thread search for pics,all you need is a sharp chisel or dremel.you don't really need a tune ,but it will make a differance .consider a mail order tune from Frost.
05-08-2010, 01:04 PM #8
05-08-2010, 01:08 PM #9
10 Hp is about right I would guestimate.
On my wifes car with a baby cam, the LS6 intake only picked the car up about .12 hundredths and a solid 1 mph on it's best pass compared to the LS1 intakes best pass.
I would suggest doing the LS6 coolant lines too. They only cost about ~$35 or so from Thunder Racing. Worth it in my opinion instead of hacking the bottom of the intake.
05-08-2010, 01:09 PM #10
05-08-2010, 01:23 PM #11
05-08-2010, 02:50 PM #12
Intake Manifold
By 10erg01 in forum Parts Wanted / TradeReplies: 3Last Post: 01-20-2011, 04:55 PM -
Pro-Flo XT LS1 EFI intake manifold
By Alexander Abraham in forum External EngineReplies: 0Last Post: 05-26-2010, 08:55 AM -
LS6 intake manifold and 227 Intake runners
By IT_SS in forum Internal EngineReplies: 4Last Post: 07-07-2009, 02:11 PM -
WTB: Lt1 Intake Manifold
By Sphyr in forum Parts Wanted / TradeReplies: 0Last Post: 11-03-2007, 08:25 PM -
Intake manifold ?
By 99M6Z28 in forum External EngineReplies: 8Last Post: 01-22-2006, 11:55 AM
