Thread: Intake manifold ?
01-21-2006, 09:07 PM #1Junior Member
- Dec 2005
- Waco, Tx
Pewter- 1999 Camaro Z28
Intake manifold ?
I have been looking around at differenet intake manifolds and I came across the BBK intake at WS6store.com. Has anyone gave this one a try over the standard LS6 intake? They claim it flows 15% better. Any comments?
01-21-2006, 10:10 PM #2I like the way yew tawlk.
- Blairsville, GA
Red- 2000 T/A WS6
I think you're better off with an LS6 intake. The BBK may flow better, but the aluminum it's made of will be more of a heat sink, making the incoming air hotter, thus less dense, thus less oxygen to burn the gas in the mixture, thus less power. Make a lick o' sense?
01-21-2006, 10:14 PM #3
Originally Posted by Ric
wise man he is
01-22-2006, 07:04 AM #4Junior Member
- Dec 2005
- Waco, Tx
I forgot about that! Thanks man.
01-22-2006, 09:08 AM #5Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
agreed. you could look into the FAST 78 setup, but id much rather spend less on the ls6 for the same amount of flow.
01-22-2006, 09:56 AM #6Senior Member
- Sep 2005
- New York, NY
Collectors Edition Yellow- 2002 Pontiac Trans AM WS6
if you have the money and plan on going for high HP in the future then the FAST 90mm with 90mm throttle is a good setup but only if you plan on getting a minimum of a cam to help put the 90mm to work...Other then that if your going small then stick with the LS6
01-22-2006, 10:58 AM #7member since may 2000
- Dec 2002
- n/w chicago
i dont think heat soak is such the big problem that people make it out to be.
think about it, how long is the air in the manifold, not even a second.
i was going to get the bbk, but came across a used ls6 manifold for 250.
also you can easily port the bbk manifold.2000 nhra edition formula
a few bolt ons, 379 rwhp
11.96 @113.25
01-22-2006, 12:41 PM #8Junior Member
- Dec 2005
- Waco, Tx
I am thinking the same on the heat soaking situstion. I really don't go to the track and the only type of racing I really do is on the street. I mostly just enjoy spirited driving so I am really not too worried about the heat soaking.
99 pewter Z28 M6, SS hood, 10 spokes, Brembo rotors, lid, K&N, Ripper, CAGS, Pacesetter LT's, Borla, TSP ORY-pipe, O2 simulators, STB, SFC's, free mods. Cant forget about my hot fiance in the passenger seat!
01-22-2006, 12:55 PM #9LS1+LT1=980hp
- Jan 2006
- Raleigh, NC
Sunset Orange Metallic- 2001 Trans Am Firehawk
Just listen for detonation with that 99 car with the egr and stock cam. I don't like heat in my motor - cruzing or racing - it still zaps power - and you can take it to the dyno and prove it!
BMRacing LT1 - Ls1 - 4.6mod - 5.0 - Some Imports
Intake Manifold
By 10erg01 in forum Parts Wanted / TradeReplies: 3Last Post: 01-20-2011, 05:55 PM -
Pro-Flo XT LS1 EFI intake manifold
By Alexander Abraham in forum External EngineReplies: 0Last Post: 05-26-2010, 09:55 AM -
LS6 intake manifold and 227 Intake runners
By IT_SS in forum Internal EngineReplies: 4Last Post: 07-07-2009, 03:11 PM -
WTB: Lt1 Intake Manifold
By Sphyr in forum Parts Wanted / TradeReplies: 0Last Post: 11-03-2007, 09:25 PM -
Intake Manifold???????
By KITT#42 in forum External EngineReplies: 6Last Post: 03-20-2007, 11:23 AM
