Results 1 to 20 of 28
02-27-2006, 11:02 PM #1
Valvetrain noise after changing oil !!
After changing my oil, I noticed a lot more valvetrain noise. Is this normal with synthetic oil or do I have a problem.
2002 pewter z28 a4 stripper
Performance: slp lid, k&n filter, cold air kit, borla exhaust wide open,1.8 crane roller rockers,
Vinci Tuner
18'' chrome Z06, NT555 275's front, BFKADW2 295's rear, red calipers
02-27-2006, 11:10 PM #2
Did you have the old oil in for an extended amount of time?
02-27-2006, 11:20 PM #3
I don't think so, maybe 3200 or 3300 miles at most
02-27-2006, 11:50 PM #4
Synthetics tend to actually clean the old slug out of the motor...so you might get a little more noise
02-28-2006, 12:14 AM #5
Thanks, it runs perfect. It just ticks when I set a red light or just let it set at idle for like 3 or 4 minutes.
02-28-2006, 09:58 AM #6
are you sure you put new oil in, cuz that would prolly cause some noice. j/k prolly nothing it less its really loud
02-28-2006, 12:05 PM #7Detailing + Design
- Pittsburgh, PA
what kidna tick? it's prolly piston slap-but i wanna make sure you don't ahve a busted lifter.
02-28-2006, 06:42 PM #8
i've noticed the same thing.seems regular oils are better at hiding noise than synthetic's are.if i run reg pennzoil i hear nothing,if i run pennzoil platinum(the best oil ever made that turns you into an instant chick magnet)i hear the valve train constantly if i listen closely.i mix half regular half synthetic when i change oil,this seems to be a happy medium.a little noisy but sounds normal.its nothing worry about.
02-28-2006, 06:45 PM #9SUPREME member-oderator
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
You know they sell this wonderful thing if you like that, called sythetic blend
Originally Posted by YoMommasTA
lol
02-28-2006, 09:12 PM #10really?you mean the blend thats twice the price it should be?thats 15% synthetic at best?that i can make for alot less?that i can control and know how much synthetic is mixed with the regular oil?you mean that one?
Originally Posted by z_driver1
02-28-2006, 09:16 PM #11SUPREME member-oderator
- Nov 2005
- Lost in Texas
Man you are hard to convince, I bet you don't buy 50/50 premixed antifreeze either
02-28-2006, 09:17 PM #12SUPREME member-oderator
- Nov 2005
- Lost in Texas
I don't curr who ye arrr, dats funny raght thurr
02-28-2006, 09:55 PM #13
the mixed antifreeze i buy.the blend oils i don't because its more of a sales gimmick than a real product.most blends they do not list the % of each oil.plus like i said if you price it and do the math you make your own blend alot cheaper,plus control the % of each.I usually mix 25% synthetic to 75% regular.plus if you use pennzoil platinum(the best oil ever made that turns you into a instant chick magnet)you can save some gas money.i get really good mileage in all my cars + all the hot chicks dig me and give me gas money.
02-28-2006, 10:11 PM #14SUPREME member-oderator
- Nov 2005
- Lost in Texas
So instead of $9 a gallon antifreeze, you buy a $7 half gallon and half a gallon of water? OR is there some magic at work in premix that I don't know about, I was making a joke about the premix, lol
02-28-2006, 10:13 PM #15ahahahhahha....anyone that buys that premix is a tard
02-28-2006, 10:14 PM #16ooops....
02-28-2006, 10:15 PM #17
well till you buy 1 gal then go buy 1 gal steam distilled water,mix it up and fart around.its easier to buy the premixed.
02-28-2006, 10:17 PM #18SUPREME member-oderator
- Nov 2005
- Lost in Texas
distilled walmart water is good enough for me at .75 a gallon, at the end of the day it's still just a machine, a big hunk of metal
02-28-2006, 10:19 PM #19
unless you don't care what you put into your car and use plain tap water mixed with antifreeze<not wise
02-28-2006, 10:20 PM #20SUPREME member-oderator
- Nov 2005
- Lost in Texas
I don't use tap water, but I don't go overkill either, but I understand that overkill is in the eye of the beholder
Silerado Valvetrain noise
By Cool Runnings in forum GM TrucksReplies: 7Last Post: 06-23-2019, 02:46 PM -
Help: Valvetrain noise
By chieftransam in forum Internal EngineReplies: 23Last Post: 02-29-2008, 12:17 PM -
Valvetrain Noise
By 98formy in forum Internal EngineReplies: 7Last Post: 10-14-2007, 11:27 AM -
help with ls1 valvetrain noise
By uglyman in forum Internal EngineReplies: 15Last Post: 09-14-2007, 09:44 PM -
changing valvetrain set up, is .600 lift too much for 220/224?
By eviLS6 in forum Internal EngineReplies: 6Last Post: 01-31-2006, 02:35 PM
