01-30-2006, 06:39 PM #1eviLS6Guest
changing valvetrain set up, is .600 lift too much for 220/224?
My set up right now is 220/224 .583/.583 114 with cranes 1.89 gold rocker arms. We ran into an issue in the upper rpm's and cant necessarily attribute the dip in power at 6k to the rocker arms, but I do know of several other's with the same issue, in the same RPM's, with the same set up.
So I was thinking of going back to stock rocker arms, and then I figured I would go with SLP's 1.85 rocker arms as instead of dropping the lift to .551 with the 1.7's they would actually increase the lift to right about .600/.600
Im concerned with ramp rates, as the cam is only a 220/224. I am using Patriot's dual gold springs. And will be using stock length hardened pushrods.
Im hoping I will eliminate the harmonics issue here, but dont want to create another problem with the valvetrain with the aggressive ramp rate. Opinion's please!
01-31-2006, 02:39 AM #2eviLS6Guest
Come on LS1.com....
01-31-2006, 09:03 AM #3Blown, Stroked, & Sprayed
- Aug 1999
- No Where
I'm confused, your running a lift of .583 with 1.89 rockers?
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
01-31-2006, 12:45 PM #4eviLS6GuestYeah whats wrong with that? Why are you confused?
Originally Posted by Ed Blown Vert
Cam .551/1.7x1.8=.583==EEK
01-31-2006, 02:18 PM #5Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Oh the cam is .551
01-31-2006, 02:27 PM #6eviLS6GuestYour car is sick by the way.
01-31-2006, 02:35 PM #7Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Thanks
Ls6 cam n valvetrain
By 69PONTIAC in forum Parts Wanted / TradeReplies: 0Last Post: 04-04-2010, 01:24 AM -
Help: valvetrain help?!?
By WSICK in forum Internal EngineReplies: 21Last Post: 09-04-2008, 07:41 PM -
It's Not the Valvetrain... What Else?
By Sizzlenut in forum Internal EngineReplies: 11Last Post: 02-04-2008, 09:26 AM -
Valvetrain
By apollyon_01 in forum Internal EngineReplies: 2Last Post: 12-19-2007, 05:53 AM -
Valvetrain noise after changing oil !!
By pewter02z in forum General HelpReplies: 27Last Post: 03-06-2006, 05:48 AM
