Results 1 to 10 of 10
    BLKHWK Durango's Avatar
    New Brunswick Canada
    BLK TA modded 12.2@113mph
    Is my rear diff. going?????
    Hey everyone
    I have a 99 TA and last night I took of from a buddies house and the car was backed up as if I was going to back sideways and slam in in drive and jam it but I just stop looked at him and tramped it it spun like crazy then I realised 1 burn mark not 2!!!!! Never did that before and I tried again today If I'm turning 1 wheel spinning only.
    Is that my clutches, locker or a whole rebuilt and where do I go to find out????
    Thanks
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    There are debates on whether the 4th gens use differential additive. Change your differential fluid and get some additive. There are synthetic gear oils out there with the diff additive(friction modifier) already added. Keep us posted.
    If you are still "one-wheeling" the car, then most likely the clutches in the diff are on their way out.
    Coral Springs, Fl
    Sunset Orange Metalic
    You have a 99 which from what i remember is a torsen carrier. Friction modifier is not used with torsen carriers because they use spider gears unlike auburn diffs that use clutches. I would get it looked at but it sounds like you'll be needing a new carrier.
    Member werewolf's Avatar
    May 2008
    Oklahoma City, Oklahoma
    When did they switch from the torsen diffs? I have an 01 but didn't look that close at my diff when I changed the gear oil back in Nov.
    Woodbridge, VA
    Navy Blue Metalic
    1999 Z28 Convertible
    I have a 99' Z28 Convertible and it requires the additive. I assume yours does as well.
    YEP!
    My car requires the additive and I did an oild change with additive about 3000 miles ago probably should of left it alone It hooks up both wheels when leaving the trap though lol
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Quote Originally Posted by Durango View Post
    Hey everyone
    Thanks
    Torsen posi's act funny like that. There isn't anything wrong with your car
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    It more than likely was just either the pavement or the way the car was sitting. If you were rolling Not perfectly straight it could have been slipping thinking you were beginning a turn. Hell for that matter check your psi in the tires. If there is Big variance than the circumference in different from side to side currently too.
    After checking to make sure psi is even go to a empty parking lot and hit a couple small hole shots and see if it is still a 1 legger. If it isn't DON'T SWEAT IT!!
    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    My car was spining from only 1 tire.
    I change the oil on the differential and after dat it was spinning eith 2 tires
    I used Lucas/oil with posi trac aditive
    you should try that
    mine was 98 z28
    Thanks
    I think I was being paranoid It works fine I tried it from a dig and it hooks up great. I've owned the car for, well this is the 3rd summer and it never happened to me before so I figured I could give my wife and excuse to change gears No just kidding lol
    It would work though hummmm! Thanks again everybody.
  1. Rear Diff Additive
    By theorangeguy in forum Drivetrain
    Last Post: 06-27-2014, 11:26 PM
  2. Replies: 8
    Last Post: 11-25-2010, 07:19 PM
  3. Question: rear diff
    By Butch2000 in forum Drivetrain
    Last Post: 03-23-2010, 07:13 PM
  4. GTO rear Diff
    By TempleU_WS6 in forum Drivetrain
    Last Post: 12-05-2007, 07:29 AM
  5. Rear End diff
    By RATA5.7 in forum Drivetrain
    Last Post: 02-01-2006, 11:36 AM
