Thread: rear diff
    Mar 2010
    Ont , Canada
    01 Z06
    rear diff
    Hi , what size is the rear end in my 99 ws6 ? 7.5 ? or 8.5 ?
    thanks
    East of Cleveland, Ohio
    99 WS.6 - Modified
    7.5
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    7.5
    Mar 2010
    Ont , Canada
    01 Z06
    rear diff
    Cool, so what interchanges with it ? and what are the GM codes for gear ratio ? so is the s-series truck the same center section ?
    99 WS.6 - Modified
    What do you mean by interchanges with it?
    GU2 - 2.73
    GU3 - 3.08 v6 gear
    GU5 - 3.23
    GU6 - 3.42
    Mar 2010
    Ont , Canada
    01 Z06
    rear diff
    well mine howls , I can't find any in my area , but I have a s truck with 3;73 , in it and it's a 7.5 , 31 spline , ? so will the guts fit ?
    Member Baluchitherium's Avatar
    It has a big wing!
    When I had my 98' TA the rear would randomly howl at low speeds.Like when driving around a parking lot.
    I changed out the fluid and never had a problem after that...
    Just a thought,hope you get your situation worked out.
    Member Numba1TA's Avatar
    Feb 2008
    Missouri, STL
    1999 Trans Am WS6 A4
    if its howling it could also be a bearing. drain the fluid and see if there are any metal shavings
  1. Rear Diff Additive
    By theorangeguy in forum Drivetrain
    Last Post: 06-27-2014, 11:26 PM
  2. Replies: 8
    Last Post: 11-25-2010, 07:19 PM
  3. Is my rear diff. going?????
    By Durango in forum General Help
    Last Post: 05-09-2010, 05:36 PM
  4. GTO rear Diff
    By TempleU_WS6 in forum Drivetrain
    Last Post: 12-05-2007, 07:29 AM
  5. Rear End diff
    By RATA5.7 in forum Drivetrain
    Last Post: 02-01-2006, 11:36 AM
