Results 1 to 10 of 10
    Junior Member 98goldta's Avatar
    florida
    gold
    1998 trans am
    Rebuilding engine, timing chain help!
    I am in the process of putting the engine back together when I got to the cam sprocket I have slop still in the chain. I bought a new ls2 chain but reused the crank and cam gears. now is this because I didnt purchase new gears. Or, is this normal. when I disassembled it I thought I had chain stretch, thats why I got the new chain. The crank can move a little in each direction before the cam moves. I know on small blocks there is no movement, but on ls1's I dont know. Do metal gears wear that much? Thanks for any help in advance.
    1998 Gold T/A 1 of 235 built, 3.08 moser 12 bolt, k&n filter, TB mod, egr mod, Lingenfelter 3.5" alum ds, Pcv oil catch can, BMR Lca's, Bilstein HD Shocks, Poly Sway Bar bushings, Full Ram Air Hood, optima red top, 220000 +miles ,never been to track Currently motor and tranny being rebuilt
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    How many miles on the original gears? I see a scary number in your signature
    The chain will have some slop, which is normal.
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    Pull all the slack to one side, and 3/8" of slack is normal... Even my double chain had that much new...
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    florida
    gold
    1998 trans am
    Yes that is about how much slack I have. yes the motor had 220,000 miles on it. other then rotted hoses the engine ran fine. it was the tranny that was making grinding noises so while I had the engine out with the tranny I thought it needed freshening up. If they let me post pics I could show you the slack.
    Feb 2007
    St Thomas, PA
    You have to use a web host, like http://photobucket.com/
    Upload to there, then from there to here !!! LOL
    florida
    gold
    1998 trans am
    Thanks for the help, here are the photos of the slack chain
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by 98goldta View Post
    If you're getting more than a couple degrees difference between the cam and crank when the chain is under tension, I'd replace them.. The only way to make things more acurrate is to run timing gears.. But other than that you'll always have some chain lash with sprocket and chain valve train.. You can tell if the chain/spocket is going bad or bad, with a timing light. Bad chain or sprocket makes the timing mark irratic and the motor will have to be torn apart again. Imho, why chance it? just my .02.
    Jun 2009
    coon rapids, MN
    2000TA
    will a lose chain effect the knock sensor?
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by garygnu65 View Post
    I suppose you could but I'd imagine on a mild cam or stock the difference between the cam and crank position would have to be substanial. By then I would think there would be cam/crank sensor issues.. Just a threory and my .o2 though.. "The tighter the train the better..." imho
  1. timing chain
    By RedHot99T/A in forum External Engine
    Last Post: 01-31-2011, 02:58 AM
  2. LS2 Timing chain set
    By sammy burks in forum Parts For Sale / Trade
    Last Post: 03-24-2008, 11:02 AM
  3. timing chain
    By emotionalpiracy in forum Internal Engine
    Last Post: 02-11-2008, 03:03 PM
  4. Ls1 timing cover, Dual row timing chain
    By xssive in forum Parts For Sale / Trade
    Last Post: 08-06-2007, 06:41 PM
  5. Ls2 Timing Chain
    By phoenix1987 in forum Internal Engine
    Last Post: 08-22-2006, 06:28 AM
