05-01-2010, 01:03 PM #1
Installing Proform short throw shifter
Like the title says I bought a Proform Short Throw Shifter I hear it is an fairly easy install. Anybody have pics or tips before in get started? thanx for the help. I have an 99 SS M6.
05-01-2010, 02:27 PM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
You'll have to remove the center console to start. Then remove the rubber boot - should have some screws holding it down to the floor. This will give you access to the top plate of the shifter. Then just remove the four bolts from the top plate. Then remove the shifter - you may need to use a bit of leverage to get it out. I did on mine. Then just reverse the steps to install. Some use rtv sealant between the top plate and the tranny as well. Good luck.
05-01-2010, 03:59 PM #3
Thanx for the info!
05-01-2010, 04:46 PM #4
05-01-2010, 05:20 PM #5
Question: My new short throw shifter
By flotty in forum Manual TransmissionReplies: 2Last Post: 05-09-2010, 07:42 AM -
noise after installing short throw
By mockler in forum Manual TransmissionReplies: 2Last Post: 07-08-2007, 04:12 PM -
dropped T40 tool while installing short throw shifter
By AntsSilverC5 in forum CorvetteReplies: 5Last Post: 06-16-2007, 09:05 PM -
short throw shifter
By ban-one in forum Manual TransmissionReplies: 44Last Post: 02-26-2007, 02:22 PM -
What is the best short throw shifter for the LS1??
By importssuck in forum Manual TransmissionReplies: 12Last Post: 12-05-2005, 07:43 AM
