Results 1 to 13 of 13
    Member importssuck's Avatar
    IL
    What is the best short throw shifter for the LS1??
    What short throw shifter is the good to use? The B&M, kirban, pro 5.0, Lou stick, Hurst are all of them pretty much the same? Like in size and design? What differs between of all the short throw shifters that are in the market? What do you guys and gals like and perfer to use? Also any pics?
    2 is better than 1!!! noblesramair's Avatar
    Illinois
    sunset orange
    2002 pontiac trans am WS6
    i just bought lou's short stick with a pro 5.0 from afterthoughtauto. Ive been told thats the best combo. Supposively the pro 5.0 makes a little noise but not bad, ill guess ill find out when i install it.
    Senior Member GottaHaveLS1's Avatar
    Connecticut
    1999 Trans Am M6
    I have a the SLP shifter for my T56 and i'm pleased with it. The throw is much shorter than stock. I'm not sure if more expensive shifters for the T56 that claim they are counterbalanced or weighted are worth it. I drove a civic with a balanced short throw and it was really easy to move. My SLP can feel a little heavy.
    constant modder councelor hissin'98's Avatar
    Utah
    Black '98 Z/28 M6
    H/C/Turbo....why?
    I have the pro 5.0 and it rocks. It does make a little noise but it's well worth it mostly because of the stock rubber absorber is gone and is now a solid shaft. My bud also runs a 5.0 in his fox mustang. Very short throw and very crisp engagement.
    Bronx
    Guest
    Hurst?
    I had a Hurst put in at the factory and added the "ole style" T-Bar handle in Gainsville. Works fine. As long as you man handle it a bit.
    somewhere
    A car
    Pro 5.0 stick has enough thread that it can be cut down at least 1". I've seen people take more off and use some kind of plastic foam sheet around the stick to hold the handle on. By far, that's the cheapest, most reasonable option with that shifter. I'm using a TNA stick from E-bay. It works fine, wish it was positioned further to the left though.
    Member Flobeast385's Avatar
    NC
    1999 TA M6
    Pro 5.0 here and I love it although if its quiet you can here about everything going on in the tranny. I think it is built a little tougher than some others and has great adjustments.
    Senior Member MadSeason's Avatar
    Indiana
    Pro 5.0 with lous short angled stick. retains same angle as stock pro 5.0 but shifts are much shorter. love it over the hurst
    Old user ButchN's Avatar
    MA
    2013 Coupe
    Quote Originally Posted by hissin'98
    It's not "noisy" from that.
    It's that peopel usually cut too much of the stock bottom rubber boot away & you now hear the road noise you never heard before.
    MA
    2013 Coupe
    Quote Originally Posted by Joe K. 99 Zeee!!
    I cut 1.5" from mine & my Hurst shift knob still screwed on no problem.
    Tech Junkie hammertime's Avatar
    Belleville, IL
    Pewter Metallic
    Lous short stik with factory Hurst - made a huge difference in feel for the $$
    Hammer - hammertime.us
    2001 Light Pewter Metallic Camaro SS, 6 speed
    K&N, SLP Lid, SLP y-pipe, GMMG cat-back, Lou's Short Stick - more to come!
    Quote Originally Posted by hammertime
    i have that, but i think it's terrible combo...it takes a lot of pressure to shove the stocker into the freakin' gears...
    somewhere
    A car
    Quote Originally Posted by ButchN
    Yup. I did that. I need to replace that part and try again. FYI for others...The rubber piece blocks off the hole in the floor where the shifter connects to the tranny. You need to cut it wider to install the Pro 5.0. I cut mine a bit too wide in one corner and I can literaly see the ground below the car when I take my center console off! A tight seal should definitely help.
  1. Question: My new short throw shifter
    By flotty in forum Manual Transmission
    Last Post: 05-09-2010, 07:42 AM
  2. WTB: Short Throw Shifter 93-02 Z28
    By karpetcm in forum Parts Wanted / Trade
    Last Post: 05-15-2009, 06:55 AM
  3. short throw shifter
    By ban-one in forum Manual Transmission
    Last Post: 02-26-2007, 02:22 PM
  4. SLP Short Throw Shifter
    By themack56 in forum Parts For Sale / Trade
    Last Post: 03-28-2006, 04:53 PM
  5. v6 short throw shifter
    By 01redm5 in forum V6
    Last Post: 11-21-2005, 08:36 PM
