    Apr 2010
    Kansas City
    1998 Z28 Camaro
    Mods list...ET/rwhp expectations???
    I drop my car off Thur to have all the work done. I'm pumped cant wait...
    98 Z28 camaro M6. 145k but runs well still. Had a compression test on motor. everything was great, tranny as well.
    free ram air mod
    EGR cutoff
    Iridium plugs & MSD 8.5mm wires
    LMPerformance high flow water pump
    ported stock TB
    BBK SSI intake manifold
    Comp Cam .595-.598 lift 232/234 @ 0.05 part# 54-446-11 (pushrods & springs)
    pacesetter long tube headers & y pipe (no cats)
    Timing chain
    3.73 gears
    flowmaster catback
    Dyno tuned
    I'm hoping for high 11s with traction and over 400rwhp. Am i a lil too optimistic or realistic? what do you guys think?
    South Carolina
    1998 Z28 Camaro
    I had about the same setup myself with a smaller cam -218/220 and made 360 rwhp. So I would say its possible. As with the time I can't help you with that, with my setup the best I could get was 13.0 very very traction limited.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    Quote Originally Posted by 98z28mesh View Post
    free ram air mod
    EGR cutoff
    ported stock TB
    Timing chain
    3.73 gears
    flowmaster catback
    Dyno tuned
    traction will limit you...quite a bit
    Shepherd, Michigan
    98' trans am
    also who will be tuning your car?
    free ram air mod
    EGR cutoff
    ported stock TB
    Timing chain
    3.73 gears
    flowmaster catback
    Dyno tuned
    i'd say a bit optimistic with out any head work done... i'm going to say you'll put down 370-380 rwhp or so... low 12's high 11's with a good tune won't be much of a problem if you get traction and a good 60'...
    Shepherd, Michigan
    98' trans am
    that is the biggie ..assuming he is mostly stock..his suspension and tires will be holding him back all the way.
    huh??? he posted his mod list...
    Shepherd, Michigan
    98' trans am
    those are the mods he is getting......i am referring to if he has any other mods that are already installed.....which i assume he is stock before the mods he posted
  1. List of Mods.
    By juanZ28 in forum Camaro / SS
    Last Post: 04-28-2011, 09:39 AM
  2. First mods/to do list...
    By StuntmanMike in forum Firebird / WS6
    Last Post: 09-08-2007, 05:23 AM
  3. free mods list
    By luvmyz28 in forum Camaro / SS
    Last Post: 05-25-2007, 06:51 AM
  4. V6 Mods list
    By Xs-Style in forum V6
    Last Post: 01-14-2007, 01:26 PM
