Thread: A4 buzz as i start moving
04-29-2010, 10:57 AM #1I f@#ked the prom queen
- Oct 2008
- Missouri
drivers' morale daily.- Destroying Mustang-
ok, this came up on another thread, and now i'm worried...while talking about the "normal" unique things that an A4 does, i mentioned that mine will "buzz" once i start moving forward (only after turning it on -- if i put it in park, then drive again, it doesnt do it)...it seems almost like the ABS system is "checking" itself...usually about 5-8 ft of movement and it's a quick vibration that i can feel in the brake or gas pedals...please help, i have no idea what this is doing, and the idiot mechanics here (at a GM dealership nonetheless) have told me its normal
04-29-2010, 06:09 PM #211 years of bangin gears
- Jan 2009
- North Jersey
Kinda sounds like the traction control system from the description. I am not familiar with the A4s though. Might be the ABS pump is on the fritz? Or maybe a sticking caliper? These cars have so many sensors that are linked there could be alot of explanations.
I have heard that the rear speed sensors have been installed too closely on the rear reluctor rings on the half shafts causing the T/C to go crazy. Look under the rear and check the clearance between the rear sensors and reluctor rings with an old credit card. If the card won't fit between the sensors/rings, then the sensors have to be shimmed.
Keep us posted.
04-30-2010, 05:49 AM #3I f@#ked the prom queen
- Oct 2008
- Missouri
i turn my TC off as soon as i start the car, so i don't think TC has anything to do with it...but that IS a very familiar feel so you might be onto something...no codes have shown up in a GM diagnostic tho...wouldnt a sensor-fail or prob with a sensor send a code???
04-30-2010, 05:24 PM #411 years of bangin gears
- Jan 2009
- North Jersey
I am not sure about getting a code if the rear sensors are hitting the reluctor rings. This is a mystery.
05-01-2010, 11:40 PM #5Junior Member
- Aug 2007
- australia
hypo yellow- 2002 vx ss
abs check system dont worry its normal worry if it gets worse cheers Nav.
05-02-2010, 06:22 PM #6I f@#ked the prom queen
- Oct 2008
- Missouri
thanks
Help: speakers buzz
By transamgirl89 in forum Stereo and ElectronicsReplies: 2Last Post: 09-24-2011, 09:23 AM -
Help: Rado Buzz
By donkill in forum Stereo and ElectronicsReplies: 2Last Post: 07-17-2011, 01:43 PM -
M6 Shifter Buzz
By Tickwomp in forum Manual TransmissionReplies: 10Last Post: 12-16-2008, 02:42 PM -
New Camaro, No Buzz?
By wantsumuscle11 in forum Camaro / SSReplies: 15Last Post: 11-30-2007, 09:26 AM
