Results 1 to 3 of 3
Thread: Rado Buzz
    Sep 2010
    Indiana
    2001 Trans Am
    Radio Buzz
    One year ago I purchased a 2001 trans am. I do not have a good/clear history on this car. It must have had an upgraded head unit removed (wires chopped) and a delco head unit was put in. This delco unit "may" have been the original. A wire harness was "patched in" which matches up with the current delco unit, but leaves one wire hanging. The cd player works fine. The radio has a "buzz" that it picks up from the motor. As I accelerate the "buzz" follows the rpms. I have questions.
    1. There are 16 wires coming from under the dash and only 15 loose ends available on the "patched in" harness. Why?
    2. The "buzz" is similar to those from am radios we had in cars back in the "60s". What can I do?
    Member Double0me's Avatar
    FT Carson
    Blue
    1999 Blown Trans Am
    I have a 99 TA and want to say I have 14 wires out of the harness, But your best bet would be to look up the wiring diagram online. As far as the buzz could be from Power and Signal wires being to close, also could be a bad ground. Best bet would be to grab a chunk of loom and separate the power from signal wires and find a good ground and long wire and start testing.
    Sep 2010
    Indiana
    2001 Trans Am
    Thanks for your help
    I have since purchased a new head unit. My problem went away. Thank you.
  1. Help: speakers buzz
    By transamgirl89 in forum Stereo and Electronics
    Last Post: 09-24-2011, 09:23 AM
  2. M6 Shifter Buzz
    By Tickwomp in forum Manual Transmission
    Last Post: 12-16-2008, 02:42 PM
  3. New Camaro, No Buzz?
    By wantsumuscle11 in forum Camaro / SS
    Last Post: 11-30-2007, 09:26 AM
