Results 1 to 20 of 20
    NY Representative Vertiviper's Avatar
    Feb 2006
    New York
    99 Trans Am, M6
    SFC Install Tips Needed
    I will be installing my UMI 2pt tubular bolt in SFCs this weekend by myself.
    The instructions that come with them are sort of vague to say the least.
    I know the car's suspension has to be loaded and the LCAs (one at a time) come off to get the rear on.
    Does anyone have any headache saving tips?
    Thanks.
    Member pewterz55's Avatar
    Jul 2009
    chicago
    light pewter metallic
    1999 z28
    make sure you torque everything to spec and use loc-tite the first time. jack stands on the rear and i used my jack under the k member and rested the front wheels on steel ramps with the jack there for double protection. easy install if done properly. did u order from KY cuz i got mine from there and it had step by step simple intructions
    Feb 2006
    New York
    99 Trans Am, M6
    Quote Originally Posted by pewterz55 View Post
    The instructions are for a 3 pt...I was concerned the process may be different.
    What do you have to unbolt in the front?
    Jul 2009
    chicago
    1999 z28
    i did the 3 point on my car but it should be similar. The only thing you need to unbolt is the rear lcas. and you'll see the holes once you get under the car for the front. you just slide that steel piece up in there and fish the screws through. (if its simialr to the 3 point install). its real easy just ignore the part about bolting it to the center which is only like 2 steps
    Member lsgunner28's Avatar
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    did mine this past weekend, hardest thing was grinding off the paint so I could weld them in. I thought it was a very easy install, although i have a pit so it made getting under it really easy. i used a little PB on the LCA bolts to make it a little easier..
    2000 Z28 M6 125,XXX: SLP lid, K&N, 10.4mm Taylor plug wires, Frost Tune, P&P TB, NGK Iridium plugs, Magnaflow Cat back, BMR SFC's and tower brace, TSP LT's and ORY, LS6 intake, MAC Girdle, UMI LCA's and Panhard, LS7 Clutch Kit, so far..
    Jul 2009
    chicago
    1999 z28
    man i wish i had a pit. the hardest part for me was jacking the car up lol. once it was up everything fell into place
    Member sjgreen6's Avatar
    Dec 2009
    Mechanicsburg, PA
    Navy Blue
    2002 Trans Am WS6 Conv
    Smile
    +1 on putting the front wheels on ramps then put the rear axle on jack stands so that the car is level. Everything else is easy. Did mine in about an hour by myself (wife comes out every so often to make sure I haven't crushed myself). Do be sure to use a torque wrench to get them fully tight. It was a little tricky getting the right angle on the rear bolts and still being able to put some muscle on it but still very doable. I also put a dab of locktite on each bolt just to be sure.
    Steve
    Jul 2009
    chicago
    1999 z28
    yea torqueing those back bolts was kinda a bitch haha
    Feb 2006
    New York
    99 Trans Am, M6
    I don't have a torque wrench, is it possible to overtighten?
    (I really need to just go and buy a torque wrench already)
    Jul 2009
    chicago
    1999 z28
    the back are very hard to tighten. depending on how much leverage you can get depends on if you can overtighten or not. id suggest getting a torque wrench. i bought the husky one from home depot, $75 and i use it all the time now that i have one.
    Member dbrichrider33333's Avatar
    Hebron, IN
    Yellow
    2002 CETA
    im going to be installing mine soon..would it be a good idea to drive the front up onto ramps and then jack the rear up and slide ramps under the rear tires, so the suspension is fully loaded??
    Member RedSmokey's Avatar
    CA (sacramento)
    F250
    Quote Originally Posted by dbrichrider33333 View Post
    I would imagine a jackstands on the axle would be just the same? But i could be wrong. I would like to know the same thing as i am about to do some weld in UMI 2pt SFC
    Jul 2009
    chicago
    1999 z28
    good luck driving up ramps. i couldnt find a pair my car could drive up on. but with the jacks on the axles it will simulate the car being loaded. and remember dont tighten the bolts while the car is up, wait til its on the ground
    Feb 2006
    New York
    99 Trans Am, M6
    When I jack up the rear end and put boards under the back tires. Do I also need to chuck the wheels when I remove the front of the LCA on each side or will the rear end not move much?
    Hebron, IN
    Yellow
    2002 CETA
    might have to use a couple boards to lengthen out the incline a little so it isnt as steep..
    Jul 2009
    chicago
    1999 z28
    put boards under the back tires? just put the axles on jack stand thats all you need for the rear
    Dec 2009
    Mechanicsburg, PA
    Navy Blue
    If you can't drive up on your ramps because they are too steep just jack up the front on each side until you can get the tire on the ramp. For the rear, as long as you have the axle on jack stands (each side of the dif) so that the rear tires are at the same height as the front tires the suspension is loaded and you are ready to install.
    When you disconnect the front bolt of the rear control arm (do this one side at a time only) the rear should not move or will only move a touch. If it moves you can slide your jack under the rear and nudge it back into position. Mine didn't move at all.
    I recommend that you connect the rear of your SFC first then once the bolt is in place with the nut finger tight swing it up and you will be able to accurately align the front bolts with the plate that you have to slide up into the frame.
    Definitely get a torque wrench. Well worth the investment over the years knowing you got it right when you are doing important work.
    Auto Painter RyanJM's Avatar
    Houston, TX
    Make friends that own shops. I got a friend who owns a midas and one who owns a vette shop so I can use a lift and tools at midas and have my vetter friend tackle the big stuff. I paint cars at my shop no time fo motor work.
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
    Feb 2006
    New York
    99 Trans Am, M6
    Alrighty guys, I think I have pleanty of info here..after this plus i'm installing a pro 5.0 shifter...the car is gonna feel completely different, hopefully!
    Feb 2006
    New York
    99 Trans Am, M6
    They went in smoothly, tightened everything down to spec..no creeks, no clunks..car handles ALOT better!
  1. heavybag/boxing tips needed
    By krese in forum Almost Anything Goes
    Last Post: 01-20-2011, 11:17 AM
  2. Tips needed
    By axcellclan in forum Parts Wanted / Trade
    Last Post: 12-22-2008, 03:15 AM
  3. lower a-arm bushing removal tips/help needed
    By 2MuchFun in forum Suspension and Handling
    Last Post: 08-20-2007, 04:58 PM
