Results 1 to 11 of 11
    Dec 2009
    Camden, South Carolina
    Citrus(burn't) Orange
    Header bolt broke off in head?
    I just put LT headers on my car and i noticed when i pulled the factory stuff off, there were only 5 bolts on the driver side while the passenger side had 6.
    And at first i thought maybe it was made that way, until i put the headers on and there was a slight exhaust leak around cylinder 1 but when i try to put a bolt in it, it wont go in far enough to thread.
    if it is a broke off header bolt how can i get it out without pulling off the head and taking it to a machine shop?
    NeW YoRk
    2001 ws6
    cant you see the bolt? is it sticking out from the head or is it in the head....if theres a small peice of the bolt sticking out theres options
    Dec 2009
    i can not see the bolt at all.
    Member lsgunner28's Avatar
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    should be able to get a small right angle drill in there, i used an air powered on, took forever though. my back two were busted off, got one drilled and tapped but the passenger side broke my extractor off in the hole and i couldnt drill though it so i made a bridging bracket.
    Senior Member karpetcm's Avatar
    Tujunga, CA
    01 Camaro 6speed
    If you spray it down with WD-40 or PB blaster a few times and let it soak will it still have issues with breaking bolts. I plan on spraying some WD-40 a few times and letting it soak overnight before taking it to the exhaust shop for the header install. Also lsgunner28, whats a bridging bracket ?
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    I took the torch to a piece of 5/16 steel scrap i had here to bridge from the 6th cylinder header bolt to the bolt hole that is back an 1 1/2" from the last header bolt on the passenger side so that it pinched the header back to the block. ill see if i can get a picture..
    Dec 2009
    it was broke off when i bought my car but didnt leak with the factory exhaust manifoldS. yea get a pic posted of the "bridge" you made
    TerribleTed TerribleTed's Avatar
    California-Sacramento-Roseville
    2000 Chevy Camaro Z28
    WOW,,,Funny,,,
    I had to yank my drivers side cylinder head off,,and even though its all stock,,I had the 6-th bolt busted off too in the cylidner head,,,the one closest to the fire wall,,,
    I left it,,,i had no leak before,,and have none now,,,
    I wonder if the factory just over torqued them,,or a common vibration broke them,,
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    i cant get a good pic with everything in the way.. sorry man.
    Dec 2009
    well i was debating if i wanted to pull the head off or pull the whole motor and trans out to fix it and do a little work to the motor and trans while it was out. But i figured i would try option 3. i went to advance auto parts and bought some stuff in a tube that is used to patch or seal up header cracks and holes. So i loosened the header and pulled away from the motor while i squeezed the metal patch liquid behind the cylinder 1 exhaust port. Let it drive for about 36 hours and doesnt leak at all. been driving it for 2 days now and now problems yet. so needless to say it was alot cheaper(10 bucks) than pull motor out or apart!
    Member natews6's Avatar
    Apr 2010
    Missouri
    1999 WS6(sold) 2003 Cobra
    Quote Originally Posted by usafshelley View Post
    Good thinkin. That stuff should hold up pretty well too.
  1. Soooo....my 10 bolt broke
    By TK THE TRUCKER in forum Drivetrain
    Last Post: 06-03-2015, 06:11 PM
  2. header bolt broke
    By Darkrider02 in forum General Help
    Last Post: 04-05-2011, 04:21 AM
  3. Broken header/head bolt.
    By 98maro in forum General Help
    Last Post: 01-14-2011, 11:12 PM
  4. broke my 10 bolt
    By 01outlaw in forum GM Trucks
    Last Post: 09-15-2007, 02:34 AM
  5. Header Help / Cam Help / Head Help
    By HOUPTIE03 in forum Corvette
    Last Post: 02-19-2007, 04:07 PM
