Thread: T56 cable???
04-18-2010, 09:22 AM #1
T56 cable???
I am pullin out my 6-speed, T56 tranny and I don't know what this cable is, or how to take it off. I think its the speedo cable but not for sure? Its on the drivers side of the case between the transmission and bellhousing. Its a steel braided cable with a yellow connector. Its the last thing holding me up, and I cant figure out how to remove it without breaking it. Please help!!!
98 Z: 6 speed, Comp cam, ported and polished heads, double valve springs, long tube headers.x-pipe with Bullets, Granatelli M.A.F.sensor/ lid.,and wires, 3:73's, Nitto 555R, tuned by Tennessee Motorsport. More in the future!!!
04-18-2010, 09:53 AM #2
- Apr 2008
- Madison, WI
Thats the clutch hydraulic line from the master cylinder. Its a quick connect style connection. There is a special tool to release it but you can release it by pushing the white plastic ring in towards the transmission. You can use 2 flat blade screwdrivers to do this. It needs to be pushed all the way inside the fitting. Then the line should just pop out on it own or with a gentle tug. If it doesn't come out its not released, keep trying. It can be a pain...
04-18-2010, 10:20 AM #3
Thanks, I had no ideal what is was! I now have it out and ready for a rebuild!
04-18-2010, 11:33 AM #4
my nylon was split and i used the two screwdriver method once. next time i bought 3/4 inch tool from autozone, works awesome
04-19-2010, 04:50 AM #5
Yeah my plastic was broken also. But the screwdrivers worked great. Now its time to crack open the case and start rebuilding it!
Cable Help.
By eball218 in forum Computer & TuningReplies: 3Last Post: 08-28-2010, 12:56 PM -
Cable X Wanted
By xpauliber in forum Parts Wanted / TradeReplies: 0Last Post: 06-17-2007, 06:27 PM -
Amp Cable
By bluetahawk in forum Stereo and ElectronicsReplies: 2Last Post: 04-29-2007, 07:36 PM -
OB2 cable
By Phlash_riot in forum Computer & TuningReplies: 1Last Post: 11-21-2006, 03:21 PM
