Thread: High Idle P0507
    Northern California
    98 Z-28
    High Idle P0507
    I recently got my intake manifold gasket replaced...about a month ago. The truck runs well but ever since I got it back from the shop, it has a high idle. It will idle at about 25 mph. It does not do this when the motor is cool, but when it gets to normal operating temperature. I talked to my mechanic and he says its probably something with the IAC since he had the throttle body off and cleaned it. He said he would fix it...no charge but he is about 80 miles away from where I live. Anybody have any ideas before I drive it up there?
    The truck is a 98 K1500 with the 5.7 L31 motor. I have a basic scanner and this is what the freeze frame said:
    DTC for which Freeze Frame was Stored P0507
    Fuel System 1 Status Closed Loop
    Fuel System 2 Status Closed Loop
    Calculated LOAD Value 17.65 %
    Engine Coolant Temp 192.20 °F
    Short Term Fuel Trim - Bank 1 -2.34 %
    Long Term Fuel Trim - Bank 1 -3.91 %
    Short Term Fuel Trim - Bank 2 -0.78 %
    Long Term Fuel Trim - Bank 2 -4.69 %
    Intake Manifold Absolute Pressure 19.25 inHg
    Engine RPM 1,575.75 rpm
    Vehicle Speed Sensor 59.03 mph
    Air Flow Rate Mass Air Flow Sensor 5.33 lb/min
    Absolute Throttle Position 17.65 %
    Do any of these categories look out of whack?
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    You did this at speed?
    Northern California
    98 Z-28
    Quote Originally Posted by JaycenK View Post
    This was where the computer freeze framed it.
    ls1 powered seabee sutie's Avatar
    oxnard, ca.
    red and black
    1999 Formula/WS6
    what ever happned with this? did you figure out why P0507 came up?
  1. idle issues... idle high. unplugged tps runs good?
    By okiels1 in forum Firebird / WS6
    Last Post: 12-31-2016, 03:36 AM
  2. high shift points & high idle
    By Red 99 T/A in forum General Help
    Last Post: 07-26-2010, 08:04 PM
  3. high idle
    By egod in forum General Help
    Last Post: 06-16-2010, 02:34 PM
  4. Question: high idle
    By mark21742 in forum Computer & Tuning
    Last Post: 08-27-2009, 09:13 PM
  5. High idle
    By kev70ss in forum External Engine
    Last Post: 01-27-2008, 01:40 PM
