Results 1 to 3 of 3
Thread: high idle
08-26-2009, 09:51 PM #1
high idle
I just put a 3,800 stall in the goat. 220/224 .570/.580 112lsa cam. I have my idle set at 775 rpms, it idle good anf stays there but in gear and moving it wants to idle all the way up to 1300+ rpms.....throttle cracker is zeroed out. am I missing something? IAC is sitting at 10-12 ° when idling at 775, would cranking the idle stop set screw closed alittle fix this or is it in the tune?
08-27-2009, 08:32 PM #2
Adjust it so that the blade closes some. Look for 55-75 steps at hot idle. Once you do this, you will want to re-do your idle airflow tuning. Additionally, while you may get by with the TC table zero'd out, I like to add 1.5-1.7g in the 400 RPM column everywhere except 0 MPH as a kind of a 'catch' in case you ever have a big dip while moving. It is helpful when beginning tuning and definitely can't hurt to leave in there.
08-27-2009, 09:13 PM #3
ok thank you again!
idle issues... idle high. unplugged tps runs good?
By okiels1 in forum Firebird / WS6Replies: 2Last Post: 12-31-2016, 03:36 AM -
Question: High Idle
By 00hawk109 in forum General HelpReplies: 20Last Post: 05-10-2011, 01:45 PM -
high shift points & high idle
By Red 99 T/A in forum General HelpReplies: 5Last Post: 07-26-2010, 08:04 PM -
High idle
By kev70ss in forum External EngineReplies: 3Last Post: 01-27-2008, 01:40 PM -
High idle?
By yellowv in forum General HelpReplies: 4Last Post: 04-12-2007, 05:03 PM
