    Junior Member tbowman's Avatar
    Apr 2010
    Connersville, IN
    1994 Trans Am
    Car wont shift till 7000-7200 rpms???
    I'm new to F-Body's first of all.. I just bought a built 94 Trans Am, I dont know all the specifics on the car because the guy I got it from didn't build it.. With that said, it is cammed, alum heads, 3500 stall, 4.10 gears.... The problem is it wont shift until 7000 rpms if i manually shift it, and if I leave it in drive it will shift boom, boom ,boom real quick (even under wot)... I've tried to short shift it manually (bump it to second gear at 5000 rpms) and it still goes to 7000... Detent cable adj didnt change anything other than the shift points under normal driving... Is this controlled by the computer???? Thanks Troy
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    if it has a cable, then its not computer controlled. But a 94 should be computer controlled
    Senior Member
    texas
    2000 formula
    did he change it out to a 4L60??? or TH350.........400???...........94 was the 1st yr for the 4L60E
    Apr 2010
    Connersville, IN
    1994 Trans Am
    700r4 is the tranny(has a detent cable)... Someone told me that the springs on the governor are too heavy.... Does anyone know if this is true????
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    sounds like its a race car huh?....thats some high rpm's for street drivin.
    Apr 2010
    Connersville, IN
    1994 Trans Am
    Quote Originally Posted by needls1again View Post
    It pulls hard to 6500, past that it kinda noses over and then takes of hard again when it shifts.... If I had a solid roller cam I wouldnt care but Hyd rollers just dont make that high hp past 6500... I think the car would pick up at the track a couple tenths if it would shift sooner...
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Something going on in the govnor. 700r4 is not by any means a drag trans. lol they don't last that long and few people can actually build them to hold the power. Not to mention that if you want to change shift points through the gov is a the way.
    Apr 2010
    Connersville, IN
    1994 Trans Am
    Quote Originally Posted by JaycenK View Post
    Thanks everyone for the info....
  1. Idle wont drop under 3000 rpms, If this happens to you.
    By florida4thgen in forum General Help
    Last Post: 03-08-2014, 10:47 AM
  2. Help: my A4 wont down shift. Why
    By mglangley21 in forum Automatic Transmission
    Last Post: 03-27-2012, 08:37 AM
  3. cant shift fast in higher rpms
    By Darkrider02 in forum Manual Transmission
    Last Post: 09-24-2010, 11:28 AM
  4. SHIFT HAPPENS...you wont believe this
    By 02cetransam in forum Almost Anything Goes
    Last Post: 08-29-2007, 12:57 AM
  5. Cant shift at high rpms
    By LTLDEV1 in forum Manual Transmission
    Last Post: 05-17-2007, 10:22 PM
