04-07-2010, 07:56 AM #1Junior Member
- Feb 2010
- Nashville, TN
White- 2001 WS6 Pontiac Trans Am
Chirping/Squeaking sound (Slave Cylinder)?
There is this constant chirping/squeaking sound that I can't pinpoint. Some say it is the throwout bearing... others say it's the slave cylinder rubbing against the fork and that it could be fixed by putting some white lithium on it. So which is it? Is it a case where I can just put some grease on it and it's fine or I am I gonna have to get a new slave cylinder and most likely put in a new clutch along with it? The sound happens if I have the clutch pressed in, while I am just cruising and not shifting and also just sitting at stop lights. If I engage the clutch halfway then the chirping is more consistant. Any suggestions?
04-07-2010, 05:01 PM #2
04-08-2010, 08:12 AM #3Junior Member
- Feb 2010
- Nashville, TN
So the 2001's don't have a clutch fork? I had a 96TA and the clutch fork broke and I had to get a replacement. So are the 98-2002TA's totally different? I haven't worked on the transmission yet to know. Also read somewhere that replacement slave cylinders aren't recommended unless they from GM... also there is a fix to drill it out so it shifts better. Are there any better slave cylinders?
04-08-2010, 08:24 AM #4Junior Member
- Feb 2010
- Nashville, TN
Also thanks again for helping me out Cutlass!
04-08-2010, 05:01 PM #5Senior Member
- Apr 2008
- Madison, WI
Nope, the slave cylinder is the clutch actuator. It looks like this
Help: Chirping/ grinding sound from valve cover
By dethinboots in forum Internal EngineReplies: 11Last Post: 09-09-2016, 09:45 PM -
Mastery Cylinder or Slave cylinder problem?
By chris5 in forum General HelpReplies: 7Last Post: 08-02-2012, 09:59 PM -
chirping sound
By kempfer99ta in forum External EngineReplies: 6Last Post: 09-13-2009, 06:05 AM -
Squeaking Sound
By Fade2Black in forum General HelpReplies: 8Last Post: 11-14-2007, 01:42 PM -
Squeaking sound?
By bgable in forum General HelpReplies: 3Last Post: 07-05-2007, 09:44 AM
