Thread: which parts should i order?
04-02-2010, 05:11 AM #1
I'm finally getting around to fixing my car and I need a new torque arm and motor mounts. Which company should I get? Which website has the best deals for these parts. Should I get a new trans mount too?
04-02-2010, 05:36 AM #2Senior Member
- Jun 2008
- Rochester, NY Rochesterracing.com
- 2000 Camaro B4C
ive always been a fan of UMI, good quality parts and great customer service
04-02-2010, 05:39 AM #3None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Try KYspeed. They're a sponser on here. Mark should be able to hook you up with what you need.
04-02-2010, 06:10 AM #4
04-02-2010, 06:38 AM #5
Wats the difference between adjustable and not?
04-02-2010, 06:41 AM #6
04-02-2010, 06:46 AM #7
How is that beneficial? Would I be ok with the one that doesn't adjust? Cause that one is a little cheaper
04-02-2010, 06:49 AM #8
Well, if you say for instance lower your car, your pinion angle would change so you would need to readjust it.
-2 degrees is pretty common for where it should be set at. A stock non-adjustable should come set at -2.
If your pinion angle is not correct, you aren't getting the maximum benefit from an aftermarket torque arm.
04-02-2010, 07:22 AM #9
Yeah my car isn't going to be lowered anytime soon. Slp y pipe prevents that
Bought to order these parts for the Grandnational opinions..
By Murder after Midnight in forum Almost Anything GoesReplies: 27Last Post: 03-09-2011, 02:46 PM -
Parts on order
By bsteff in forum Camaro / SSReplies: 0Last Post: 03-04-2010, 07:54 PM -
Best order to install parts?
By UKRAMAIR in forum Suspension and HandlingReplies: 2Last Post: 09-10-2009, 02:16 PM -
parts soon to be on order
By PureSShp00 in forum Camaro / SSReplies: 10Last Post: 10-11-2007, 07:56 AM -
Parts to Order List BMR*
By WinSomeLoseNone in forum Suspension and HandlingReplies: 18Last Post: 03-26-2006, 08:20 AM
