Results 1 to 3 of 3
    UK
    2001 ws6
    Best order to install parts?
    Hi,
    I got a few parts to install, and wonder what is the best order in which to replace them?
    I have:
    shocks (all 4) (stock springs)
    Rotors and pads (fronts)
    Relocation brackets.
    Advise on what order to replace them to make the least amount of work, without messing anything up would be much appreciated.
    1. My guess is rear shocks and relo brackets first.
    2. Then replace front shocks.
    3. Then install front rotor and pads.
    Is that best?
    Thanks for the advise.
    Turgid Member Goat-E's Avatar
    Jun 2009
    Hollywood, Florida by way of Da' Burgh
    Impulse Blurr
    2004 GTO
    I usually go with the hardest to the easiest or what is furthest in to the outermost (DUH) depending on what is required. Your plan sounds about right. Although I am not looking at your car I think I would do the front first because it sounds more involved. Metaphorically it's like going down the mountain.
    Member Blue28's Avatar
    Ca.
    Navy Blue
    1999 Camaro Z28
    IMO,
    I would remove the front brake rotors and pad first, then change the front shocks(start on the drivers side). After you're completely done with installing the front shocks start installing the new rotors and pads. Then do rear shocks and final the relocation brackets.
  1. which parts should i order?
    By slpdablueZ28 in forum General Help
    Last Post: 04-02-2010, 07:22 AM
  2. Parts on order
    By bsteff in forum Camaro / SS
    Last Post: 03-04-2010, 07:54 PM
  3. parts soon to be on order
    By PureSShp00 in forum Camaro / SS
    Last Post: 10-11-2007, 07:56 AM
  4. Looking for a good place to order motorcycle parts...
    Last Post: 07-06-2006, 09:07 AM
  5. Parts to Order List BMR*
    By WinSomeLoseNone in forum Suspension and Handling
    Last Post: 03-26-2006, 08:20 AM
