Results 1 to 20 of 24
Thread: Broken Motor : (
03-29-2010, 06:55 PM #1
Broken Motor : (
Well my motor is broken and now I have to take it out, what gets me down is that it will be a easy 15 min job to fix it but theres no way i can do it in the car. I have to pull the whole motor out, so I was thinking of just building a 383. I'm sure this has been beat to death but, for you guys with the LS1 383 Stoker, would you guys mind what HP and Torque your cars are making N/A cam spects ect. I am leaning toward this route as of now. Thanks!
03-29-2010, 07:13 PM #2
do u want an n/a car and is it a standard?
03-29-2010, 09:12 PM #3
What happened to your motor?
03-29-2010, 10:45 PM #4
03-30-2010, 03:25 PM #5
03-30-2010, 04:37 PM #6
whats ur budget? i wouldnt ever rly call a stroker motor a budget build my 408 was expensive as hell but u gotta have some idea with what u wanna spend
03-30-2010, 06:49 PM #7
03-30-2010, 09:31 PM #8
I have about 4500 that I want to spend on it. Ive been looking hard for a 6.2L with the L92 heads, I plan on using all the rest of the parts from my current motor, Cam, Springs ect. I know it will be about 5k so as long as i don't go over that i'm good.
My current motor is broken from where that starter bolts up on the outside bolt goes ( the Ear of the block), I can push start the car and it's fine but....I guess I could park on a hill all the time lol. I am going to pull the motor and fix it but I'm sorta using this as an excuse to go big, if you know what i mean.
03-31-2010, 03:44 AM #9Senior Member
- Apr 2008
- Madison, WI
That sucks. Did you read this thread?
04-02-2010, 12:33 PM #10
Na I hadn't seen it but yea that's what mine looks like. My battery wasn't weak but my old starter locked up, and my battery was fine. It wasn't weak like the other guy stated. Well I'm looking for a L92 motor now I thinkthat will be my next motor, if I can find one
04-03-2010, 08:46 AM #11
what cam are u running now and intake ,heads, etc etc
04-03-2010, 06:02 PM #12
Erson cam 620/620 int/exh 236/242 @.50, the heads are ported procomps that flowed about 290, not that great of flow but ok I guess. Intake is ls6, stock throttle body mass air all that stuff. Long tubes, ud pulley.
04-03-2010, 06:09 PM #1311 years of bangin gears
- Jan 2009
- North Jersey
Have you thought about having the ear welded back onto the block? If funds aren't allowing for a bigger build, why not try to save that motor and build up your money stash for your build?
04-03-2010, 06:13 PM #14
Yea I have thought about it, it's not that I don't have the money I want to build it but I'm being a tight ass I guess but I think I have made up my mind to do it anyway. I was just debating myself, but I love cars and I want a good build so...
04-03-2010, 07:02 PM #1511 years of bangin gears
- Jan 2009
- North Jersey
Hmmm...maybe a 6.2 from a wrecked Escalade? Just an idea.
04-03-2010, 07:18 PM #16
if ur gonna re use ur heads,cam, etc... u can order a short block fully built for around 3800 from several vendors and since u live in midland id just get it from TSP cuz its in lubbock thats what i did when i lived in midland lol
04-03-2010, 07:44 PM #17
Yea man in regards to that can I use all my accessories valley cover for knock sensors oil pan, timing cover, oil pan all that stuff. I heard I could but I want to hear it frompeople that have done it or that have seen a friend do so.
04-03-2010, 07:51 PM #18
for my 408 lq9 i reused my oil pan, valley tray, timing cover etc for the most part all parts for the 4.8,5.3,5.7 & 6.0l blocks are interchangeable id buy a new timing chain (double roller) and a new ported oil pump but is u wanna save u can re use it just make sure and clean it rl good so u dnt get any old trash in a new motor
04-03-2010, 07:54 PM #19
also if u get a stroker make sure and space ur windage tray down accordingly
04-06-2010, 09:33 PM #20
Windage tray?
Car Got Broken In To
By Spikito in forum Camaro / SSReplies: 2Last Post: 06-26-2008, 01:13 PM -
Need help pulling motor - broke motor at a road course event
By Doc99SS in forum General HelpReplies: 20Last Post: 08-24-2007, 05:57 PM -
Car broken into
By Danger731 in forum Western MembersReplies: 10Last Post: 06-21-2007, 09:25 PM -
Broken headlight motor gear?
By Ryanater in forum Firebird / WS6Replies: 7Last Post: 04-20-2007, 01:16 PM -
Is my AMP broken?
By 02_WS6 in forum Stereo and ElectronicsReplies: 5Last Post: 01-07-2007, 11:41 AM
