Thread: Started my LT install
03-27-2010, 11:48 AM #1
So I started my LT header install this weekend, its going pretty good so far, have everything out including EGR, AIR, and Alt. just working on the motor mounts now.
Anyone have any tips for re-installing everything?
thanks2000 Z28 M6 125,XXX: SLP lid, K&N, 10.4mm Taylor plug wires, Frost Tune, P&P TB, NGK Iridium plugs, Magnaflow Cat back, BMR SFC's and tower brace, TSP LT's and ORY, LS6 intake, MAC Girdle, UMI LCA's and Panhard, LS7 Clutch Kit, so far..
03-27-2010, 12:19 PM #2
With the motor mounts. You have to take off the base that's attached to the kmember. Once youre passed that and the headers are in; make sure you thread in by hand all the bolts to the motor mount while everything is loose.
Don't be like me and get 6 of the 8 bolts in and the last two holes won't align so you'd have to undo everything and redo it all over.
Any other questions let me know. I went through it last weekend
03-27-2010, 04:00 PM #3Senior Member
- Jan 2010
- texas
silver- 2000 formula
http://www.ls1.com/forums/showthread.php?t=133419
sum nice pics
03-29-2010, 12:47 PM #4Member
- May 2009
- Manitoba
blue- 1998 Trans Am ls1
03-29-2010, 02:07 PM #5Senior Member
- Jan 2010
- texas
what ever works
03-29-2010, 04:44 PM #6
Did you guys put the passenger side mount in before or after the header? I cant find any way to slide them in with the header in..
03-29-2010, 05:29 PM #7Member
- May 2009
- Manitoba
with the header out, i dont see any other way to do it, alt and air comp and bracket moved forward, gave me much more room, u-joint socket with extensions really hepled too, damn its tight in there. i just finished the mount install for both sides tonight, all went suprisingly well! its not all that bad
How to Get Started in 3 Gun
By Ed Blown Vert in forum Gun's & AmmoReplies: 0Last Post: 09-29-2011, 01:50 AM -
Started install of ZEX
By jambofla in forum NitrousReplies: 2Last Post: 05-15-2009, 04:30 AM -
Started Pacesetter Install
By nc2k2z28 in forum External EngineReplies: 17Last Post: 07-09-2008, 01:17 AM -
Started my new top install today!!!
By shawn84&92 in forum ConvertibleReplies: 10Last Post: 04-07-2008, 09:12 AM -
Started the Heads/Cam install today.
By juiced99ws6 in forum Internal EngineReplies: 84Last Post: 04-24-2007, 04:23 AM
