03-16-2010, 09:59 PM #1Senior Member
- May 2009
- Toronto
SOM- 2002 SS
Header Question : EGR delete? o2 ext ??
Ok so from what i gather I need o2 extensions ? I read in the sticky that they can be tuned out... is there a o2 bung further upstream in the header and one further back in the collector? is part # Bosch 13111 just for the rears that can be tuned out anyways? if so hell with spending $100 on something ill tune out anyways.
headers I got are non-ugly. i mean non-egr. what do I need to block off and remove all that emissions crap??
Also wanted to ask anyone know where i can buy Poly engine mounts? figured I'd have them installed too so i can tuck up the headers nice and not worry about the drivers side pipe banging the floor.
TIA
03-16-2010, 10:07 PM #2Just me
- Nov 2006
- Broken Arrow, OK
LS1 cars have 4 02 sensors, 2 before the cats, 2 after the cats. Removing the cats does away with the rear ones, those are the ones you need to get tuned out.
The ones before the cats relocate with long tube headers and you need the extensions for those, or the Bosch 13111. Most people spend the $25-$30 on extensions and re-use the 02 sensors they already have. If you want to spend the bucks on those Bosch 13111, go right ahead, but you really don't need them if you purchase the extensions.
Since you already have the LS6 intake, and you got emission free headers, you don't need any block-off plates. Just yank out the AIR pump and all its hoses and have the associated codes turned off for the AIR and rear 02 sensors.
03-16-2010, 10:26 PM #3
You can also use Denso 234-4087. Some claim to have better results with those.
Get in touch with Markls1ta on here about the mounts, I'm sure he can get them. He doesn't have them listed on his site though.
03-16-2010, 10:47 PM #4Senior Member
- May 2009
- Toronto
SOM- 2002 SS
Thanks so much that explains alot. so I don't need the actual o2s I didnt realize i just need the extensions. anyone have part #s or where to buy extensions?
Also with the EGR im assuming it just pumps air to the exhaust for faster cat light up only? so no piping to the manifold at all?
thanks !
03-16-2010, 10:56 PM #5Senior Member
- May 2009
- Toronto
SOM- 2002 SS
For mounts I was looking at the prothane engie+trans combo. Im not too worried about vibration but I'd imagine this will definitely help with engine movement over stock? right now my 3" ory smacks the drivers side on wot and I dont want it happening with my new lts/y or I'll
03-17-2010, 03:11 AM #6
03-17-2010, 06:46 PM #72002 Arctic White T/A
- Sep 2009
- Houston , Texas
Metallic Pewter- 2002 SLP Firehawk
ok so with teh egr i have an 02 it doesnt have egr but the headers i purchased do have egr fitting i bought a pair of egr gaskets and block offs...what do i weld onto it just the plates or both gaskets and block offs??
03-18-2010, 10:15 AM #8
03-18-2010, 10:43 AM #9Senior Member
- Jan 2010
- texas
silver- 2000 formula
as far as i know.....prothane are the only ones making poly MMs........no???
and i dont think my motor will be rocking around much with the polys now
Quick Question EGR/AIR Delete
By ChevyZ76 in forum Camaro / SSReplies: 10Last Post: 02-15-2017, 07:56 AM -
o2 delete question
By razer900 in forum General HelpReplies: 14Last Post: 10-28-2009, 12:25 PM -
AIR Delete Question
By Sweet Chops in forum Computer & TuningReplies: 20Last Post: 04-14-2009, 03:48 PM -
Resonator Delete Question
By surfinjoe in forum GTOReplies: 40Last Post: 08-26-2008, 07:21 PM -
I have a serious question. Mods please dont delete.
By FSANE in forum Almost Anything GoesReplies: 44Last Post: 08-03-2006, 01:24 AM
