Results 1 to 15 of 15
Thread: o2 delete question
10-28-2009, 08:33 AM #1Member
- May 2009
- Manitoba
blue- 1998 Trans Am ls1
o2 delete question
Going to be installing ps lt headers, tsp ypipe and exhaust system for next spring. As of now the car has no cats, and Iam assuming the previous owner has pulled the bulb from the ses light. Wanting to do the egr delete and o2 delete as well. Just a bit confused with the o2's, can i get rid of all 4 of them or just the 2 after the cats? I will be getting a mail order tune after install. Thanks in advance
10-28-2009, 08:43 AM #2
I think you have to keep the first 2 but you can delete he rear o2's
10-28-2009, 08:49 AM #3Member
- May 2009
- Manitoba
right on, sort of what i thoght, but when it comes to electronics, iam screwed. cant wait for the header install!!!
10-28-2009, 09:30 AM #4Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
does your ses light come on with the key and then go out? or never seen it altogether?
10-28-2009, 09:40 AM #5Member
- May 2009
- Manitoba
i can turn the ignition on without starting it, and nothin... and have never seen it on, i can see where it should be tho. Iam assuming the previous owner yanked the bulb when he removed the cats?
10-28-2009, 09:47 AM #6
You can delete all 4 if you go with a speed density tune. At that point you don't need your 4 O2's or MAF. It is common to just delete the rear O2's
10-28-2009, 09:47 AM #7
And yes the bulb is dead. You're supposed to get a 30 second bulb check
10-28-2009, 10:42 AM #8Member
- May 2009
- Manitoba
good info! and what exactly is a speed density tune?
10-28-2009, 10:54 AM #9
A speed density tune is basically a locked in A/F ratio to the PCM where the PCM calculates fuel and spark based on vacuum. So basically you now utilize the map sensor not the MAF. So instead of reading and reporting to the PCM Mass Air, you get vacuum. More reliable, less shit to break, and no more MAF issues. Only down side is every mod you do, you need a retune. So be sure you do this after a big set of mods. A lot of cars today use Speed Density. Chryler Corp is the biggest. Our cars come with both Map and MAF. The map in the current setup is only for EGR purposes and MAF is the main calculation factor. Speed density, no more MAF, all calculations done my MAP and other sensors
10-28-2009, 11:06 AM #10Member
- May 2009
- Manitoba
well said, thanks. kinda over my head tho. lol
10-28-2009, 11:08 AM #11
NP Yeah it's pretty crazy stuff. Leave it for the tuners trust me on this. It gets nasty trying to understand how the system works
10-28-2009, 11:19 AM #12Member
- May 2009
- Manitoba
to sum it all up, i can tune out and remove the egr and rear o2's. Any other issues or concerns with this setup? Is there such a thing as a cat delete as well?
10-28-2009, 11:26 AM #13
Yes, you can delete your EGR, AIR, CAT, O2's MAF, you name it. My setup right now is a speed density tune. No Cats. No O2's, No MAF, AIR or EGR and I have a 98
10-28-2009, 11:28 AM #14
I've been running that way for about 10 years now so guys know how to do it. Just finding the right tuner to perform it. Ask guys from your area and find a respectable tuner. I wouldn't do speed density though until you have a good H/C in the car. Standard tuning, they can delete your rear O2's, AIR, and EGR
10-28-2009, 12:25 PM #15Member
- May 2009
- Manitoba
all your info is much appreciated!! thanks again!!
Quick Question EGR/AIR Delete
By ChevyZ76 in forum Camaro / SSReplies: 10Last Post: 02-15-2017, 07:56 AM -
Header Question : EGR delete? o2 ext ??
By 5abivt in forum External EngineReplies: 8Last Post: 03-18-2010, 10:43 AM -
AIR Delete Question
By Sweet Chops in forum Computer & TuningReplies: 20Last Post: 04-14-2009, 03:48 PM -
Resonator Delete Question
By surfinjoe in forum GTOReplies: 40Last Post: 08-26-2008, 07:21 PM -
I have a serious question. Mods please dont delete.
By FSANE in forum Almost Anything GoesReplies: 44Last Post: 08-03-2006, 01:24 AM
