Thread: Automatic Trans Swap
03-16-2010, 10:24 AM #1
Will an automatic transmission from a 2002 f body be a direct swap into a 97 f body?
03-16-2010, 11:35 AM #2
no. the torque converter input shaft is different (can't interchange the converters) and the converter to the flywheel bolt pattern is different as well. you could, however, have a converter built with the right bolt pattern to mate to the flywheel maintaining the same input shaft spline count.
i also do believe the pins are different on the plug and harness too. maybe someone will chime in for verification of this.
03-16-2010, 06:56 PM #3Senior Member
- Apr 2008
- Madison, WI
I think the bellhousing is different also
03-17-2010, 03:40 AM #4
also the dowl pin holes are a slightly different size that you may or may not have to resize. bell housing will still mate up, but the top center hole won't be used and there's no hole for the the top right if my memory is right.
03-18-2010, 05:22 AM #5
Thanks for the info. Keeps me from getting one that will not fit right.
Automatic to Manual Swap
By bobh13908 in forum Manual TransmissionReplies: 1Last Post: 10-06-2011, 05:37 PM -
manual to Automatic swap
By Rk ws6 in forum Automatic TransmissionReplies: 32Last Post: 01-05-2011, 05:53 PM -
Question: Automatic Swap out for 6 speed???
By tlurkws6 in forum Automatic TransmissionReplies: 12Last Post: 09-01-2009, 06:10 PM -
Advice on automatic trans am
By fastassbird05 in forum Automatic TransmissionReplies: 1Last Post: 02-18-2007, 09:51 AM -
Automatic to Manual 6 Speed Transmission Swap - Possible? - Impossible?
By Pyromaniacal in forum LT1Replies: 2Last Post: 07-25-2006, 06:56 PM
