Results 1 to 13 of 13
Thread: throttle sticking help????
03-15-2010, 07:41 AM #1
I just took out my 99 SS since it has been in storage and drove it around and noticed when I remove my foot off the throttle at around 40 mph the car does not slow down so I put the car in nuetral its a automatic and rpm is around 1900 rpm. When I stop at at a light or stop sign the car is at idle around 700 rpm which is normal. What sensor or part could it be? has anyone experienced this before?? I'm thinking IAC sensor but I don't want to buy it and it not fix problem. The car is bonestock except for a lid and k&n. any input would will be helpful thanks in advance.
03-15-2010, 07:43 AM #2King 0f n00bz
- Jan 2006
- Shepherd, Michigan
well the throttle positioning sensor would be a better culprit then the IAC. However. drive the car a little more and see if the problem fixes itself. stored cars can do funny things for a little bit.
03-15-2010, 08:49 AM #3
03-15-2010, 12:40 PM #4
Sounds like you're driving a Camry....
03-15-2010, 12:55 PM #5
03-15-2010, 01:33 PM #6
03-15-2010, 05:14 PM #7
i took everyones advice and traded it in a Toyota.
Just kidding I cleaned the IAC sensor and replaced the Throttle Postion Sensor and fixed the problem. Thank you for the great advice.
The SS is like new runs like a champ.
03-15-2010, 07:04 PM #8
03-15-2010, 09:34 PM #9
03-17-2010, 03:13 PM #10
my turds doing the same thing, did it few months ago then fixed itself, started again today, guess ima do some cleaning
03-17-2010, 03:23 PM #11
03-17-2010, 05:43 PM #12
03-18-2010, 05:14 PM #13
ok thanks, im going to this weekend
Can a stuck tranny valve cause my throttle sticking???
By TahoeTruk in forum General HelpReplies: 13Last Post: 02-13-2016, 05:55 PM -
Throttle sticking/hanging
By SpinsB in forum General HelpReplies: 33Last Post: 08-12-2009, 07:33 AM -
Help: Throttle sticking
By 2000dreambird in forum External EngineReplies: 3Last Post: 08-12-2009, 06:04 AM -
Throttle sticking after battery disconnected
By txcosmos in forum GTOReplies: 17Last Post: 09-19-2006, 01:32 PM -
Throttle sticking from each shift, all RPM's
By 981LEZ28 in forum General HelpReplies: 6Last Post: 02-08-2006, 08:11 PM
