Results 1 to 20 of 34
    Undertaker During the Day SpinsB's Avatar
    Cincinnati
    2001 Pontiac WS6 427ci
    Throttle sticking/hanging
    About a month ago I took my TB off and cleaned it up. Not to dirty but still a little gunk behind the throttle blade. Had the car out last night and noticed the throttle sticking/hanging on me. Like if I was cruising at 40 and would put the clutch in the throttle would stick or stay at 2000rpm. Got on interstate and was going 70 put the clutch in and the rpm's went up and hong there. I would have to hit the gas a little and it would then come down to idle. Pedal not sticking and the throttle moves find when i checked it by hang. Any thoughts please??
    2001 WS6 LS2 427ci Forged Callie Crank, Billet Steel Compstar Connecting Rods, Forged Aluminum Wiseco Ceramic Coated Pistons, Stage III Ported & Polished Racing LS1 Cylinder Heads, F.A.S.T. 90/90, TTS LT's, GMMG exhaust, Spec stage III clutch, 18/19 iForged Aero's, Koni 4/4 Strano Springs.
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    You may be over thinking this? Did it do this before you cleaned it or did not check this before? I ask because the throttle follower and throttle cracker etc. in the PCM tables purposely hold the throttle up while you shift or let off the gas in gear so as to not slam the throttle shut. It's that way for fuel economy purposes. There's a decay associated with both so if you wait it will come down. A quick check would be to run the RPMs up while you're not moving. If it doesn't hang it is a pretty good bet that there is no mechanical issue with the throttle.
    Cincinnati
    Quote Originally Posted by DaddySS View Post
    No its never done this. It will stick at 2000rpms for as long as i would let it but i would hit the gas pedel and it would drop then. But I understand what your saying but I dont think that is the prob. I could coast for 40 feet ect and the rpms wouldnt move from where they were while driving
    Check your cable and make sure it's not binding. Another thing I've seen them do is the cable stick a little bit instead of sliding back into the sleeve. I always spray a little wd-40 on the ends of the cable to keep everything lubed up there. Did you take the tb off when you cleaned it? If so just make sure your cable is hooked back up correctly.
    Cincinnati
    Yea took TB off and made a point to hook cable back up in the same spot it was before. where do you spray the wd-40. When I noticed this happening I checked the cable and it seemed to be sliding fine. Can they become lose? Any adjustment to them?
    Member planemech2's Avatar
    Greybull, Wy.
    Black/Black/Black
    2000 Camaro SS Vert #5301
    If you took your TB apart, make sure you got the little spacer/lock back on the throttle shaft under the position sensor. Also check that your return spring has tension on it. That spring is the only thing that closes the throttle when you lift your foot.
    2000 SS vert, #5301, triple black, A4, leather, 3.23,SLP lid & D/D, STB, chrome 5 spokes
    USN '64-'88
    #3 1951-2001
    www.fquick.com/planemech2
    Cincinnati
    If I was to go out to the car right now and flip the throttle by hand it will flip back with no problems. No issues at all.
    in my Trans Am
    2000 Trans Am WS6
    yeah check the cable like stated before and check your spring....may not hurt to pull off your TPS and just give it a review
    Cincinnati
    Quote Originally Posted by TransAm11973 View Post
    review? hows that work
    in my Trans Am
    2000 Trans Am WS6
    your throttle postion sensor, driver side of throttle body, bottom sensor. Its attached with a safety screw. Take it off and look at the sensor and the exposed section of the outside of the TB now that the sensor is off. You will see the end of the TB shaft that goes into the sensor. Just make sure nothing looks abnormal etc. I just mentioned this as another thing to check out. It more then likely is not this. Although you could have abnormal buildup where the TB shaft sits in the TB. More then likely it is a spring issue, a TB blade issue(getting stuck on carbon build up etc. in the TB), or throttle cable issue...Do you have traction control, if you check your cables from the TB all the way back to the traction control module. Check for binding, catching etc. It is a good idea to move the TB blade by hand to see if you can replicate the sticking.......This being done with the car turned off and the intake off so you can see the TB blade moving.
    Junior Member johno's Avatar
    Harrisburg,PA
    Black &Gold &Tan Inside
    2001 WS6-NHRA
    hi, my car is doing the samething.you name it and i check. i hope some can HELP.
    Harrisburg,PA
    2001 WS6-NHRA
    hi, i have to say i try the wd40 it seems to be working. thanks fot the tip
    Cincinnati
    Quote Originally Posted by johno View Post
    where did you spray the wd40 at along the cable ??
    Harrisburg,PA
    2001 WS6-NHRA
    my car is back doing samething
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Could it be a sticky IAC? This symptom sounds like what my last car used to do. Drive and press clutch and the revs would rise a little, then when stopped the idle would slowly drop to normal.
    Cincinnati
    IAC??
    North Jersey
    2004 GTO M6
    Quote Originally Posted by SpinsB View Post
    IAC??
    Idle Air Control solenoid. It regulates the incoming air at idle. Sometimes it will get carbon deposits and will hang up causing a slow return to normal idle speed or will cause a surge while shifting a manual transmittion equipped vehicle.
    Cincinnati
    where do I find it? how can I clean it. Funny thing is my car has always had a hard time finding its idle. Surges alot unless I come to a complete spot and even then sometimes it still seems to search for its idle. so maybe that needs cleaned.... tell me tell me tell me
    Member foxman92's Avatar
    Jun 2009
    oklahoma
    01 SS
    its the top sensor on the drivers side of the throttle body, has two hex bolts holding it in... i just replaced mine, and it cost me $115.. i tried to clean mine, but it just simply needed to be changed.. good luck
    Cincinnati
    k. so wheres the TPS then?
  1. Can a stuck tranny valve cause my throttle sticking???
    By TahoeTruk in forum General Help
    Last Post: 02-13-2016, 05:55 PM
  2. throttle sticking help????
    By naperws6 in forum General Help
    Last Post: 03-18-2010, 05:14 PM
  3. Help: Throttle sticking
    By 2000dreambird in forum External Engine
    Last Post: 08-12-2009, 06:04 AM
  4. Replies: 17
    Last Post: 09-19-2006, 01:32 PM
  5. Throttle sticking from each shift, all RPM's
    By 981LEZ28 in forum General Help
    Last Post: 02-08-2006, 08:11 PM
