    Z28 FOR SALE thelastz28's Avatar
    Fontana, CA.
    Sebring Silver Metallic
    2002 Camaro Z28
    Question Engine Noise Upon Acceleration?
    2002 Z/28. When I accelerate, hear a noise in my engine bay. Sounds like "Tapa-tapa-tapa". The more I accelerate, the noise sounds more rapid (no pause between the noise). It started when I put my Hooker LTs and my GMMG. Does anyone know what this noise might be. The belts arent hitting anything, even though it sounds like it. Only when I accelerate.
    2002 SSM Z/28 - 351 RWHP & 369 RWTQ
    Wheels 4 sale -> http://inlandempire.craigslist.org/pts/261643333.html
    Fontana, CA.
    2002 Camaro Z28
    I really need some help guys. I hope its nothing too serious. I dont want to break down on the freeway. Thanks guys.
    Tech Junkie hammertime's Avatar
    Belleville, IL
    Pewter Metallic
    Two possibilities jump out at me since you just installed headers:
    1) just the sound of exhaust pulses in the tubular headers, iron manifolds absorb that sound so readily, you'd never hear the individual pulses.
    2) an exhaust leak at either the cylinder head (just one cylinder) or the collectors (four cylinders)
    Hammer - hammertime.us
    2001 Light Pewter Metallic Camaro SS, 6 speed
    K&N, SLP Lid, SLP y-pipe, GMMG cat-back, Lou's Short Stick - more to come!
    Member Capster78's Avatar
    Newport News Va
    1998 WS6 M6
    Id have to say its most likley an exuahst leak. Check your header bolts and make sure they have not backed out. It is usually recommended to torque them back down after awhile due to the heating/cooling of the headers (expansion and contraction of the headers could cause the bolts to back out). If that doesent work you may want to check your header gaskets and make sure they are seated properly. Or it could possibly be that your hearing more valvetrain noise thru the headers. Could be a rocker arm tapet thats worn and causing the pushrod to rattle against it or it could be a lifter.
    Fontana, CA.
    2002 Camaro Z28
    Thanks a lot guys. I will re-torque the header bolts to see if that helps.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Just don't put anti-seize on em. . .they'll never back out again lol
    Fontana, CA.
    2002 Camaro Z28
    Thanks for the heads up z_driver1, I wont do that.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    good good, I'd hate to find out someone didn't know I'm a jackass and did it after reading that
  1. Help: Acceleration issue and unrelated/related noise.
    By Speed Bump in forum General Help
    Last Post: 06-17-2009, 11:27 PM
  2. Noise under hard acceleration-auto tranny related
    By Zapper2003 in forum General Help
    Last Post: 03-14-2008, 05:31 PM
  3. Replies: 3
    Last Post: 03-02-2008, 06:23 PM
  4. cracking noise on hard acceleration
    By zetwentyeight in forum Automatic Transmission
    Last Post: 12-18-2006, 01:18 PM
  5. Major mysterious clunking noise under acceleration...
    By F-body fan in forum General Help
    Last Post: 08-11-2006, 07:38 PM
