Results 1 to 13 of 13
    Spark Plug Heat Shields
    As part of my header install I replaced the spark plugs and bought MSD wires. Is it necessary to invest in a set of heat sleeves for the new wires? I saw a recent thread where the metal shields were apparently swapped over to the new wires, but this only covers the boot. What's recommended?
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    I really like my heat sleeves, just a nice added security.
    Pittsburgh
    2008 Hummer H3
    Mine has these too with springs connected to them. My stock manis are not loggers they actually have a tube for each port and those areas gets HOT. I wound use them imho.. My after market gaskets are bent steel with a roughly 2 inch shied built/bent into them but I will still use the metal boot collers. Just my .02..
    Bragg NC
    Met. Sunset Orange
    01 SS
    Lil extra protection never hurts. I personaly removed the stock head shields and used some Accel Kevlar heat shields.
    You can pick them up at most parts stores for like 50 bucks or so....
    J
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    my heat sheilds for my plugs interfered with my headers so i was forced to remove them.
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    Never had a problem running MSD wires and no shields. I don't care to wrap metal around my plug wire boots...
    Thanks for the replies! I am also uncertain about the stock pieces, especially as they only protect the boot. On the way home from work tonight I stopped and picked up a set of DEI sleeves and will see how they fit.
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    I do not have headers, and when I replaced my stock wires I kept the stock heat shields, and added aftermarket kevlar heat shields that wrap around the lower part of the wire.
    An ounce of prevention is worth a pound of cure.
    SteveC
    Just a farmboy V8MUSCLE's Avatar
    Montpelier, VA
    2000 Pontiac Trans Am
    i kept the shields, and will probably get the shields that cover the wire also. its kinda like that drunk chick at a party that looks 18 and says shes a virgin, but you still want her to pass out first and use a condom just incase.
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    Quote Originally Posted by sunsetorangess View Post
    J
    This is exactly what i did
    Senior Member
    texas
    2000 formula
    Msd wires here.........no heat shields.........and no problem
    Aug 2021
    Berecz
    2000 Firebird
    Question. Are they easy to remove and install? I am replacing plugs and wires and have a misfire.
    Oct 2021
    usa
    1999 firebird
    I too have heat shield sleeves on my plug wires.
  1. spark plug heat shield
    By 1998 T/A in forum Firebird / WS6
    Last Post: 04-19-2015, 05:40 PM
  2. Question: Spark plug wire heat shield
    By SteveCZ28 in forum General Help
    Last Post: 03-07-2011, 03:52 AM
  3. Question: Do ineed the heat shields with stock plug wires?
    By JayTA98 in forum General Help
    Last Post: 02-16-2011, 04:17 AM
  4. spark plug heat shield
    By jakez28 in forum General Help
    Last Post: 04-14-2010, 09:29 PM
  5. Spark Plug Wire Heat Sheilds
    By stevenm357 in forum External Engine
    Last Post: 06-04-2008, 06:12 AM
