Results 1 to 20 of 23
Thread: Difficulty removing rear rotors
02-24-2010, 02:23 PM #1Member
- May 2009
- Central Florida
red- 2000 Z28
Is there any trick to removing the rear rotors other than using a BFH and letting some penetrating oil soak overnight? I quadruple checked the parking brake and even cycled it several times to verify that the lever was disengaging when the handle was all the way down. With a regular hammer and a block of wood to cushion the blow, my passenger side rotor just laughed at me.
02-24-2010, 02:28 PM #2
BFsoftHammer.
Specifically a dead blow. Worked wonders for me.
02-24-2010, 02:31 PM #3
Steel wool.. Use it to clean off the hub in front of the rotor. spray a lil pb blaster on it and as Hipo says use a soft dead blow and off they will come..
02-24-2010, 02:48 PM #4
Take a propane torch and gently heat inside the circumference of the studs. Then whack the crap out of it with a deadblow hammer. Works like a charm.
02-24-2010, 03:38 PM #5
02-24-2010, 03:39 PM #6
02-24-2010, 03:44 PM #7
Just hit it with the humer
if you have a new one dont worry about old one hit it
02-24-2010, 04:54 PM #811 years of bangin gears
- Jan 2009
- North Jersey
Hopefully you don't have a large lip inside where the parking brake shoes sit. Had that happen to me. I had to close the rear adjusters to get the rotors off.
02-24-2010, 05:07 PM #9None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Some rotors had drilled and tapped holes in them and you could use a puller to remove them.
02-24-2010, 05:19 PM #10
hit it like it owes you money
02-24-2010, 05:55 PM #11
Break out the pimp hand and show that ho who's boss...
02-24-2010, 06:13 PM #12Senior Member
- Apr 2008
- Madison, WI
One of the favorite sayings at my shop, "Take the purse off your shoulder and hit that thing."
Sometimes it takes a full speed baseball style swing.
02-24-2010, 08:38 PM #13Member
- Oct 2009
- Pensacola
Red- 1998 Trans Am WS6
02-24-2010, 08:39 PM #14Member
- Oct 2009
- Pensacola
We always asked if they needed to change their tampon.
02-25-2010, 02:03 PM #15
02-25-2010, 03:32 PM #16None Shall Pass
- Jan 2010
We always said "You don't have to treat it like it's your first time with a girl - give it to it good!!"
02-25-2010, 09:57 PM #17
hit it like it owes you money, hit it like a man, and put your man pants on before you swing.
02-25-2010, 10:13 PM #18
If the BFH doesn't work...eat a can of spinach and try again.
02-26-2010, 05:17 AM #19Member
- Oct 2009
- Pensacola
Maybe an acute case granular vaginitis.
02-26-2010, 08:20 PM #20
Question: Rear rotors
By Project LS1 in forum General HelpReplies: 4Last Post: 04-27-2011, 06:11 PM -
Removing rear bird
By MudStainKILLA in forum Appearance SectionReplies: 7Last Post: 07-31-2010, 09:52 AM -
removing the rear spoiler
By VOODOOII in forum Camaro / SSReplies: 3Last Post: 08-11-2009, 01:12 PM -
Rear alignment issues after removing rear spring isolaters, adj trac bar fix it?
By anestech* in forum Suspension and HandlingReplies: 1Last Post: 06-19-2007, 07:06 PM -
Wtb: Ls1 Rear Rotors
By 1badchicken in forum Parts Wanted / TradeReplies: 0Last Post: 01-30-2006, 06:15 AM
