Results 1 to 20 of 26
    Member lsgunner28's Avatar
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    First Rear Suspension Mod.
    Hi all,
    Ok, what should be the first rear suspension mod. to help make the stock rear last longer?
    thanks!
    2000 Z28 M6 125,XXX: SLP lid, K&N, 10.4mm Taylor plug wires, Frost Tune, P&P TB, NGK Iridium plugs, Magnaflow Cat back, BMR SFC's and tower brace, TSP LT's and ORY, LS6 intake, MAC Girdle, UMI LCA's and Panhard, LS7 Clutch Kit, so far..
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Your very first suspension modification should be sub-frame connectors.
    IMO - the only thing that will help your stock rear end not blow up is a) slippery tires and b) a light foot.
    East of Cleveland, Ohio
    99 WS.6 - Modified
    A new rear end! lol! That'll really help your rear end last longer! Subframe connectors are the best way to start IMO. Shocks and springs too. But it never stops with one mod. Once you start you just keep going.
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    I have SFC's already, it has a regular differential, no posi, in it so im hoping it will last a little longer.. Torque arm, Lower control arms or what?
    Quote Originally Posted by lsgunner28 View Post
    I have SFC's already, it has a regular differential, no posi, in it so im hoping it will last a little longer.. Torque arm of Lower control arms or what?
    LCA's and a TA will both give you more traction and plant more power to the ground.
    LCAs will be less expensive on their own, but you need to also get relocation brackets to get the full benefit of using LCAs.
    99 WS.6 - Modified
    A good posi - like a detroit trutrac - would actually help some. I blew 2 stock carriers in mine before upgrading to a detroit trutrac (before switching rearends altogether). The carrier held - the gears did not - three teeth on the pinion and four on the ring. The carriers can't hold up to a lot, so switching it out to a better one could keep you rolling on stock longer. Or by rearend did you mean the carrier itself?
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    yeah, whatever the weak point is, make it last as long as possible.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    yeah, whatever the week point is, make it last as long as possible.
    The weak point on this is 7 days long....
    On a more serious note the less it wheel hops the easier it is on the whole assembly. SFC's will help keep the frame and car straight allowing it to plant better. An adjustable body mount (to get it off of the tranny - this also should have a DS loop) torque arm will allow you to adjust the pinion angle to keep it from wheel hopping.
    Relocation brackets and/or LCA's will help with getting the pinion angle back where it belongs if the car is lowered (mine isn't).
    My car is an A4 with 3400 stall and 3.73 gears. With MT DR's it does 1.73 60' all day (I know I can get it quicker - just gotta practice more) and (if I don't wind up the stall to high) is a dead hook off the line.
    Next thing I'm gonna try is a solid spacer in place of the crush sleeve to keep it from whinning.
    Typically, LCAs are the first rear suspension mod people will do after SFCs. Then on to panhard and torque arm.
    Quote Originally Posted by 67CamaroRSSS View Post
    What rear do you run?
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    The stocker 7.5". Originally was a 2.73 with Torsen. Traded that for a 3.42 with Auburn. Now 3.73 with Torsen.
    I burned out 2 Auburn's and broke a set of used 3.42's. I've replaced the crush sleeve 2X due to it being crushed even further (because of the way it hooks). Next up: Solid bushing.
    Like everybody told me I should have went straight to a 12 bolt. Next time something breaks...
    The 02 is just my cruiser/track car, it's not my DD. That's what the 98 is for.
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    so you just bought a different carrier? how long has it been holding up?
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    The Torsen has been holding up fine for almost a year now. My issue is with gear whine. Last year when I put the Torsen in I went with Richmond 3.73's. They whined. Swapped to AAM gears and they were quite enough for me (some barely audible whine on decel but not enought to matter). Now after 8 months of a min 2X/month racing (Friday night at Firebird and/or Saturday at Speed World - sometimes both) the gears are making noise. I replaced the crush sleeve and it went away but then returned. I attribute this to the crush sleeve being displaced due to the MT's being a real grippy tire (dead hook on launch after heating them up) so I'm gonna try out a solid bushing next and see how that works.
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    The Torsen has been holding up fine for almost a year now. Swapped to AAM gears and they were quite enough for me (some barely audible whine on decel but not enought to matter). Now after 8 months of a min 2X/month racing (Friday night at Firebird and/or Saturday at Speed World - sometimes both) the gears are making noise. so I'm gonna try out a solid bushing next and see how that works.
    So do you think a Torsen carrier and AAM gears would hold up in a DD? and the what Torsen carrier? or is it the stocker?
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    It was a stock Torsen that my buddy had. I believe these came in 2001/2 F-bodies (maybe 2000? Not sure on that). The AAM (American Axle & Manufacturing) gears are (suposed to be) the stock GM gears.
    As both of these are "stock" items I don't see why they couldn't work for a DD.
    FYI: The 02 is not (although it could be) a daily driver for me. I have a 98 Z28 (stock down to the air filter) for that job.
    FWIW: I had Motive then Richmond 3.73 gears that both whined (after installation and minor adjustment) prior to the AAM gears which didn't whine (at least not enough for me to care at first - it got worse with repeated launches).
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    okay, mine is a fair weather DD with 106,xxx miles, and I'm doing mods to free up more power, but I am worried about the rear end because I've read they were weak. I want to make it last as long as possible.
    NeW YoRk
    2001 ws6
    switch out the axels........
    Member godless-phoenix's Avatar
    culver city, Ca.
    Blackened fire chicken
    2000 Pontiac Trans Am WS6
    Hi all,
    thanks!
    mac rear end gurdle (cover)...i have one, no problems with the diff. since
    http://www.ws6project.com/user_stor/...oducts_id=2116
    Jul 2009
    Johnstown Pa.
    Medium Red Metallic
    Quote Originally Posted by godless-phoenix View Post
    did you have problems with it before?
    culver city, Ca.
    yeah, before i had bought the mac gurdle, i had to get my rear end fixed a couple of times until i convinced the stealership to put it on. my diff. exploded and punched a huge hole in the stock cover and all the oil poured out and my axle locked up on me, it was a nightmare...no problems at all since i put the rear end gurdle on
  1. Front Suspension Work / Completed Rear Suspension
    By bhunter0830 in forum Suspension and Handling
    Last Post: 07-02-2013, 01:23 PM
  2. Front Suspension Work / Completed Rear Suspension
    Last Post: 04-13-2013, 05:44 AM
  3. Help: rear suspension
    By o2 double s camaro in forum Camaro / SS
    Last Post: 05-22-2009, 04:51 AM
  4. Rear suspension
    By chrissm in forum Suspension and Handling
    Last Post: 01-20-2009, 05:29 AM
