Thread: Rear suspension
    Pa
    sunset orange
    2002 trans am ws6
    Rear suspension
    I am going to lower my ride in a couple of weeks and was wondering if I had to change out any other rear suspension parts to run 17x11 rear wheels. I am new with f-bodys so any help would be greatly appreciated. Also any reccomendations on springs also would be helpful.
    Member ebdboudreaux's Avatar
    Nov 2008
    Tampa, Fl
    99' 30th Ann TA
    QA1s....
    30th Anniversary Trans Am #0998
    B&B triflow exhaust, American Racing Headers, RPM Level V T-56, RPS clutch, LS6 intake, P&P TB, Hotchkis lower trailing, Panard Rod, Tower Brace, SFC's, and Swar Bar Kit, BMR Lowering Springs, HAL Adjustable Shocks and Coilovers, Powerslot Rotors
    San Diego ca
    "Arrest Me Red"
    2001 trans am
    strano spring are the best imo. give sam at stranoparts.com a call he can get you any thing you need. and he knows his stuff.
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    You will need an Adjustable Panhard Bar to recenter the rear after lowering it.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    Pa
    sunset orange
    2002 trans am ws6
    Thanks guys for the help. Like I said I'm new to these cars and was unsure if anything else needed changed. I was leaning towards the stranos or eibach kit.
    Minnesota
    pewter
    2002 Tans am WS6 M6
    if you read on here there are some negative results with the eibach kits. type it in the search link on the top of page. Most of probs come with time I think like sag in the rear.
    Drag car?? If not, skip the QA1 shocks.
    Get strano springs. Best ride, perfect height, best overall performer.
    Koni shocks.
    And as mentioned, an adjustable panhard bar is almost needed to center the rear.
    Some LCA's would keep the rear in place nicely as well.
    Lowered, HID's, tinted.
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    If you gonna lower it, you will need shocks.
    Also depending on how much you want to lower, you might not need to get springs, since you can do it w/ Koni SA (due to 2 perch locations) allowing you to remain @ stock position or lower by 3/4". Another option to consider, while having one of the best shocks available.
    Eugenio_SS
  1. Front Suspension Work / Completed Rear Suspension
    By bhunter0830 in forum Suspension and Handling
    Last Post: 07-02-2013, 01:23 PM
  2. Front Suspension Work / Completed Rear Suspension
    Last Post: 04-13-2013, 05:44 AM
  3. Question: First Rear Suspension Mod.
    By lsgunner28 in forum Suspension and Handling
    Last Post: 02-25-2010, 07:50 PM
  4. Help: rear suspension
    By o2 double s camaro in forum Camaro / SS
    Last Post: 05-22-2009, 04:51 AM
