Results 1 to 15 of 15
    Oct 2009
    alabama
    1998 ss camaro m6
    Symptoms of bad maf sensor?
    my 98 ss brought up the evaporative emissions code...unplugged the maf sensor and it seemed to make things alot better...what does this mean?
    your evap has no correlation to your maf. Any mods to the car? When was the last time you cleaned your maf sensor?
    in my Trans Am
    2000 Trans Am WS6
    you have a fuel system issue, with the evap canister system for the fuel tank
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    What code number is it?
    Oct 2009
    alabama
    1998 ss camaro m6
    Never cleaned the maf...should i try that or just replace it?...and how would i find the exact problem with the evap system?
    Stockitie Stock Stock 95camaroZNC's Avatar
    Raleigh NC
    1999 Trans Am
    Clean the maf a bottle of the stuff is 5 bucks at a auto store if that doesn't fix it continue to the next thing.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Quote Originally Posted by LS1junkie18 View Post
    Post the code number and we'll tell you.
    NC
    1998Z28
    Are you sure you just don't have a bad gas tank cap. I know if its loose or not sealing correctly it will throw that code. A bad or dirty MAF usually causes motor surging and Idle problems on my car.
    in my Trans Am
    2000 Trans Am WS6
    does it say if its with the fuel system?
    maybe your MAF was dirty anyway.....
    Oct 2009
    alabama
    1998 ss camaro m6
    checked the codes today and its bringing up P0102, P0157, and P0449...low input and low voltage i believe...Thanks for any help.
    Oct 2009
    alabama
    1998 ss camaro m6
    Help with code p0157.
    1998 SS M6...brought up codes p0157 and p0102...any help with exactly wat the problem would be is appreciated.
    Pittsburgh
    2008 Hummer H3
    From my manual:
    P0102= Mass air flow sensor circuit, low input
    P0157= O2 sensor curcuit, low voltage post converter right bank..
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    P0102 is the the code that needs to be addressed first. This is an indication you MAF has failed. Is it a factory MAF or aftermarket?
    Check this thread out for P0157:
    http://www.ls1.com/forums/showthread...highlight=code
    Build in progress...
    Oct 2009
    alabama
    1998 ss camaro m6
    Its factory maf
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    You can usually do a quick check of the MAF by tapping on the flat portion of the sensor body with a screwdriver while the car is running. If the engine stumbles or stalls, the sensor is faulty.
    You can also check voltage with the ignition key turned to the on position, car not running. Check the voltage on terminal B ground (black/white) and terminal A (yellow). There should be between 4-6 volts .
    Last, you can check the battery voltage to the MAF with the ignition key turned to the on position, car not running across terminals B ground (black/white) and terminal C (pink). Should read 12 volts.
    This is from the Haynes manual for pre-1998 V8's.
  1. P0740 (no symptoms help)
    By Letzride in forum Automatic Transmission
    Last Post: 05-22-2014, 06:26 PM
  2. Help: Cam symptoms
    By Lunatikgixxer in forum Internal Engine
    Last Post: 10-27-2010, 08:10 PM
  3. What are the Symptoms of a bad cam lobe
    By Justin93 in forum Internal Engine
    Last Post: 04-16-2009, 01:08 AM
  4. What are the symptoms of syncros going out?
    By grandkodiak in forum Manual Transmission
    Last Post: 02-12-2006, 07:46 PM
  5. Symptoms...
    By Mr. Luos in forum Internal Engine
    Last Post: 02-04-2006, 08:26 AM
