Results 1 to 20 of 35
Thread: Wires and plugs?
02-08-2010, 12:16 PM #1Junior Member
- Feb 2010
- Indianapolis,Indiana
Sunset Metiallic Organe- 2001 Camaro SS
Wires and plugs?
I have a 2001 Camaro SS with 74,000 miles on it, its idling really rough at times really after its been running for at least 10 min? The RMP's all the sudden drop under 500 and the engine shakes and acts like it wants to die?.. I'm thinking plugs and wires?? could it be other things? Thanks
02-08-2010, 12:51 PM #2
Start by cleaning the MAF and see if that solves the problem. CRC makes a MAF cleaner that you can pick up at just about any auto parts store. Next thing to look at is the hose on your PCV system to see if it is cracked and causing a vacuum leak.
02-08-2010, 01:53 PM #3Junior Member
- Feb 2010
Yeah thats what i thought but I just put an SLP MAf and a stainless steele lid and I still have this problem.. I have no cats or mufflers with headers also..
02-08-2010, 04:18 PM #4
Did you have the MAF calibrated in your computer? When ever you swap MAFs you need to get a tune so it doesn't make the engine run too lean. go ahead and grab a set of Autolite 103s and a set of wires for it to be sure
02-08-2010, 06:33 PM #5
What you describe doesn't sound like a symptom of plugs and wires. Sounds like a sensor issue to me.
No codes I'm assuming??
Best bet would be to find someone with an OBDII diagnostic program (preferrably HP Tuners, if not Autotap or the like) and see what you can find out by recording data while the problem is happening.
Plugs and wires won't hurt either, if they are original change them as well. I'd reccommend AC Delco or Granatelli wires and AC Delco or NGK Iridium spark plugs.
02-08-2010, 06:44 PM #6
There is an Idle Air Control valve on the side of the throttle body -- if that gets gummed up you can experience idle issues as well. Any chance you have an air leak between the MAF and the throttle body that would allow unmetered air into the engine? May want to check your clamps as well.
02-08-2010, 06:49 PM #7
Ding.
What MAF is it? Aftermarket?
What have you done about the O2's with the addition of the Longtubes? Extensions, home-grown splicing?
Edit: Would be helpful if you could get it hooked up to HPTuners or a good scanner that can monitor the IAC ( Idle Air Control ) counts. Scanner available?
02-11-2010, 07:16 AM #8Junior Member
- Feb 2010
I have an SLP MAF, It gets really bad when I slow down and turn into a parking spot?? I got Taylor 10.5mm thunderbolt wires coming in mail.. what spark plugs should I roll with? I was thinking E3 or NGK TR6xi?
02-11-2010, 07:20 AM #9Junior Member
- Feb 2010
Also I don't have a tuner? I bought the car with it chiped, hearders, tuned, striaght pipes.. So by putting the SLP MAF I need to get a tuner to retune it?
02-11-2010, 07:24 AM #10
02-11-2010, 07:39 AM #11Junior Member
- Feb 2010
Ok... but arent the TR6xi alittle better?
02-11-2010, 07:44 AM #12MOTOR CITY MARO'
- Nov 2005
- LIVONIA,MICHIGAN
PEWTER- 2000 CAMARO SS #3821
Take the maf off and put the stocker back on! then reset the computer and drive a while so it adjusts back to the stock maf.
02-11-2010, 08:01 AM #13
02-11-2010, 08:16 AM #14Junior Member
- Feb 2010
The website saids they work best with lightly or heavy modify engines.. Also I'm going to go ahead and get o2 sensors..
02-11-2010, 08:20 AM #15
02-11-2010, 08:34 AM #16Junior Member
- Feb 2010
ok right on
02-11-2010, 08:45 AM #17
Yup NGK or autolite 103s, stay away from the E3 plugs
02-11-2010, 09:18 AM #18
Put the stock MAF back on before doing anything.
02-11-2010, 12:26 PM #19
/\ I would say maf is the issue here. Why did you put the SLP one on?
02-11-2010, 04:04 PM #20
Like said above put the stock maf back on and see if it runs better..I put a Delphi 85mm maf on my car and it ran better and even pickup at the track..
New plugs & wires
By Redrokit8 in forum Firebird / WS6Replies: 5Last Post: 03-31-2012, 03:56 PM -
plugs and wires on ls1?
By camaross9810 in forum General HelpReplies: 12Last Post: 02-05-2011, 06:28 AM -
Plugs and wires - HELP
By burnfibl in forum External EngineReplies: 17Last Post: 04-11-2009, 09:30 PM -
Question: New plugs and wires. . .
By chrisbgood in forum General HelpReplies: 14Last Post: 09-13-2008, 05:21 AM -
Plugs and Wires Install...MSD wires E3 plugs
By Demon_Z28 in forum External EngineReplies: 13Last Post: 05-04-2008, 03:53 AM
