Results 1 to 13 of 13
    Jan 2011
    Pembroke, North Carolina
    1998 Camaro SS
    plugs and wires on ls1?
    What is the easiest way to change plugs on a 98 camaro SS?
    mercersburg pa
    hugger orange
    2004
    Luckily I have a GTO, but I've been told number 8 is easier to get to from under the car
    They are easy, except for the Number 8 cylinder. That is the one as you look at the engine that is on the passenger side all the way in the rear. There are several ways to get to it. From the top, ppl have removed the coils and used a couple of universals to get it. On mine I go from the bottom. If you still have stock exhaust you may need to move the starter out of the way to be able to get it. Ever since I got headers I have lots of room to work with.
    Member staleycornell's Avatar
    Dec 2010
    Memphis
    Black, White
    2001 WS6, 2000 SS Camaro
    Ive owned 2 GTO's and 2 F-Bodies and yes, the GTOs are a piece of cake compared to these F-Bodies. The driver side is pretty easy but the last 2 on the passenger side..not so easy. Underneath would be my best guess on the last one also.
    On the # 6 cylinder I came in just in front of the HVAC box and was using a couple of universals. Its a bitch, of course having my niece who has thin hands helped a lot.
    Get longtubes, a 1.75" long extension, and remove the EGR/AIR.
    Had my plug changes down to about 35-40 minutes.
    Lowered, HID's, tinted.
    ^^ This. A 1-1/2" or 1-3/4" extension on your 3/8" drive ratchet works perfectly. Remove the coil packs, which I understand are individually mounted on the '98, and go get No. 8 from beneath the car.
    Aug 2010
    Oklahoma City, Oklahoma
    sebring silver
    Y2K SS CAMARO
    did mine under the car but i deleted the cats before i decided to do the plugs. IMO it made it way easier
    Junior Member nmbr5ml's Avatar
    Jan 2011
    LaVista, NE
    If you've removed EGR/AIR and have headers, it's not too bad at all. Just pull all but the rearmost bolts out of the coil pack and you can rotate it up out of the way. You'll have plenty of room.
    Oh, i just realized we're talking about a 98. removing the coil packs could be a bit more of a pain.
    If you have EGR/AIR and stock manifolds, personally I would just take it to the chevy dealer and pay them 100 bones to do it. That would truly be a bitch.
    Member jsmith564`'s Avatar
    Apr 2009
    covington ga
    yellow
    2004 gto
    easy, i can do this in 30 mins from the top.
    tools;
    3/8 drive rachet (short if you have one, either will work)
    5/8 spark plug socket
    3/8 short extension
    19mm short/shallow socket (use this on the end of the spark plug socket)
    remove air tubes
    remove coil packs
    for #8 use a 3/8 drive rachet, sparkplug socket and shallow 19mm socket.
    put the 19mm shallow socket on the 3/8 drive and put the spark plug socket on the spark plug for the #8. you have to be kinda over the top on the motor and reach in but it works perfect.
    i have big arms and get #8 with ease.
    Apr 2009
    covington ga
    yellow
    2004 gto
    Quote Originally Posted by nmbr5ml View Post
    take all the coil packs all the way off. trying to leave that one bolt on the coil and work on #8 is a bitch. just remove the whole thing.
    Orlando, FL
    Mean Black
    I remove all the coil packs on passenger side. i get #8 with a 3/8 ratchet and a 6" long 5/8 socket. Don't forget to put anti-seize lubricant on the plugs
    Jan 2011
    1998 Camaro SS
    Thanks a lot guys! Info really helped out!
  1. New plugs & wires
    By Redrokit8 in forum Firebird / WS6
    Last Post: 03-31-2012, 03:56 PM
  2. Help: which plugs and wires to buy?
    By SmokinSS in forum Corvette
    Last Post: 06-04-2011, 12:47 PM
  3. Plugs and wires - HELP
    By burnfibl in forum External Engine
    Last Post: 04-11-2009, 09:30 PM
  4. Question: New plugs and wires. . .
    By chrisbgood in forum General Help
    Last Post: 09-13-2008, 05:21 AM
  5. Plugs and Wires Install...MSD wires E3 plugs
    By Demon_Z28 in forum External Engine
    Last Post: 05-04-2008, 03:53 AM
