Results 1 to 20 of 29
Thread: motor mounts
02-06-2010, 03:52 PM #1Just a farmboy
- Jun 2007
- Montpelier, VA
Pewter- 2000 Pontiac Trans Am
motor mounts
Solid VS. Poly VS. OEM
is there any real benefits to poly or solid motor mounts over the OEM ones?
02-07-2010, 06:44 AM #2Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
The OEM ones are weak and after awhile will deteriorate enough to allow the engine to move. This movement will produce a loss or torque and also have detrimental effects to the transmission mount. Mine were so bad that the I tore 2 1LE trans mounts in half before I replaced with all poly mounts.
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
02-07-2010, 06:47 AM #3
If its a DD i would stay away from solid, Poly hold up very well but transmit a bit of "road noise". Anything is better than stockers...
02-07-2010, 06:50 AM #4Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
I went with solid. I really didn't notice any change from stock driving.
02-07-2010, 07:12 AM #5Just a farmboy
- Jun 2007
- Montpelier, VA
is there any performance gain to solid or poly motor mounts?
i read somewhere that any twisting the engine/trans does in its cradle is lost power. any truth in this?
02-07-2010, 07:13 AM #6
i went with poly = prothanes but ive heard from a buddy with solids that theres no difference in drivability
02-07-2010, 09:00 AM #7
I went with poly mounts when I installed my LT headers. Definitely a noticeable difference in the amount of vibrations and noise transmitted into the cabin. Nothing horrible though, I could easily live with it on a daily basis.
As for solid mounts, I really don't see a need for that unless it a track only car and you want everything as stiff as possible. They aren't going to offer any advantages in a street car, just more vibrations and noise.
02-07-2010, 10:59 AM #8
i all so have poly's but couldn't tell but i put a cam and headers on at the same time so its hard to tell if any more noise from them. and yes and no with power it dosnt add any but yes it takes some from the wheels to twist the mount but not any thing to worry about on a street car. are cars can run solids just fine on the street but no real need to. imo
02-07-2010, 11:53 AM #9Member
- Jun 2009
- coon rapids, MN
red- 2000TA
with solids you will feel alot more vibrations ,only use them for a serious drag car.
02-08-2010, 04:56 PM #10
02-08-2010, 05:09 PM #11
you will drill the old clam shell apart put new bushing in bolt it with the bolts supplied and reinstall simple as that
02-08-2010, 05:26 PM #12
i installed spohn solids and i really like the engine response. it really gives a good throttle response to the whole car.
02-08-2010, 05:44 PM #13
02-08-2010, 10:41 PM #14
I have solids and its barely different than stock. Dont let anybody tell you solids are for 'serious' drag cars or something. I love the way it feels.
02-09-2010, 10:47 AM #15
02-09-2010, 11:07 AM #16King 0f n00bz
- Jan 2006
- Shepherd, Michigan
motor mounts dont "make" any power OP..all they would do is "restore" any power lost on engine movement.
02-09-2010, 11:16 AM #17
02-09-2010, 11:19 AM #18
02-09-2010, 06:45 PM #19
i'm running solid mounts in my goat and have just a small vibration in gear at idle
02-09-2010, 09:30 PM #20
Prothanes here, but my car does get a little vibration.
how many motor mounts on a 98 ws6
By javeryboy in forum Firebird / WS6Replies: 5Last Post: 09-19-2014, 05:09 PM -
Energy Suspension Motor mounts or prothane mounts
By Justin23454 in forum External EngineReplies: 5Last Post: 11-14-2010, 09:31 AM -
motor mounts
By TransAmFanatic in forum General HelpReplies: 2Last Post: 06-21-2009, 06:01 PM -
Motor Mounts.
By SStriker in forum External EngineReplies: 20Last Post: 09-29-2007, 11:38 AM -
motor mounts ?
By z71 in forum General HelpReplies: 2Last Post: 07-22-2006, 05:47 PM
