Results 1 to 3 of 3
Thread: motor mounts ?
    louisville ky
    maroon
    95 k1500 4x4
    motor mounts ?
    i am putting a ls1 in a 95 4-wheel drive chevy truck.i am trying to find motor mounts.can anyone help?
    Northern VA
    Dark blue metallic
    1999 Camaro SS
    I don't have a direct source right now, but you may want to look into the late model trucks. They use variants of the LSX. The trucks and escalade for instance use the 6.0l variant, some have the 5.3l, etc.
    What I don't know is how much the frames have changed on the C/K trucks from '95 to present style. ('98-'05) If the frames are about the same the mounts should/may work.
    They may still need a bit of fabbing or welding but they may be agood starting point since the other end is designed for LSX engines.
    I do think the mounts for the original are at the wrong locations so atleast it means cutting them off and welding the others on.
    Maybe others know of kits for this.
    dayton
    02 firebird
    you can get a online repair manual for 10 dollars a wk from mitchell1 ...i did it when i was installing new airbags
  1. how many motor mounts on a 98 ws6
    By javeryboy in forum Firebird / WS6
    Last Post: 09-19-2014, 05:09 PM
  2. Energy Suspension Motor mounts or prothane mounts
    By Justin23454 in forum External Engine
    Last Post: 11-14-2010, 09:31 AM
  3. motor mounts
    By TransAmFanatic in forum General Help
    Last Post: 06-21-2009, 06:01 PM
  4. Motor Mounts.
    By SStriker in forum External Engine
    Last Post: 09-29-2007, 11:38 AM
  5. motor mounts??
    By 02sscamaro in forum General Help
    Last Post: 09-22-2007, 12:22 PM
