Results 1 to 10 of 10
    Member kiddynamite's Avatar
    Indiana
    2002 Trans Am WS-6
    Whats the difference?
    i'm looking at getting an UMI panhard bar, lower control arms and relocation brackets...
    i see there are non adjustable, adjustable, double adjustable, panhard bars...now what is really the difference and what is really necessary and overkill with these?
    same with the LCA, adjustable or not?
    The adjustable units are almost a necessity if you have a lowered car, or plan on lowering it in the future. This allows you to keep the axle centered in the car and wheels centered in the wheel wells. If you go with an aftermarket rear axle you can also compensate for any differences with adjustable suspension pieces.
    Our car will never be lowered due to our wonderful northern PA roads. Although I have an aftermarket Moser 12 bolt, I chose non-adjustable UMI hardware. The only exception is my torque arm which has an adjustment to set the pinion angle. I also have welded relocation brackets for more bite. FWIIW: The fit and quality of the UMI pieces is exceptional.
    This is what my setup looks like:
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    From my understanding when using relocation brackets you need adj LCA's to keep the wheels centered in the wheel well because the mounting point has been moved back.
    As for the Panhard bar an adj. one is used to recenter the rear after installation of lowering springs but IMO it is a must because the rears are not centered correctly even at stock ride height. For the Panhard double of On car adjustable is preferred.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    new jersey
    navy blue metallic
    2000 trans am
    Quote Originally Posted by 9T8W66 View Post
    theoretically the brackets should not move the rear back. the holes are drilled in an arc so that each one is an equal distance from the body side mounting hole. unfortunately some brackets don't fit quite right and/or people install them slightly incorrectly and it causes issues.
    Quote Originally Posted by creeper View Post
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Do you plan on doing it yourself or taking it somewhere?
    Senior Member t-rock's Avatar
    pocola oklahoma
    2002 firehawk 94 Z28
    that car is so clean it looks like a peice of art
    Indiana
    2002 Trans Am WS-6
    Hey, thanks for all the input! my cars is lowered and i plan on doing it myself...so i think i'm going to get the adjustable panhard and adjustable lca's.
    and yeah, pajeff02...your car is pretty sick...almost too nice to drive!
    thanks again for the help. i appreciate it.
    Quote Originally Posted by t-rock View Post
    It's getting there. My goal is to make it half as nice as Preston's.
    Quote Originally Posted by kiddynamite View Post
    It is our summer play car. I try to keep it out of the rain and crap, but living 1/2 mile down a dirt road makes it a challenge.
    Good luck man and if you need some help or a hand, hit me up on here. I'm not too far from you. I just got an adjustable PHB from UMI myself but haven't put it on so I'd be down for helping so I know what to do when I go put mine on.
    Jon
  1. Whats the difference?
    By Sarge in forum Almost Anything Goes
    Last Post: 10-07-2009, 06:09 PM
  2. Question: Whats the difference between these????
    By blackSS01 in forum Internal Engine
    Last Post: 06-07-2009, 02:12 AM
  3. Question: whats the difference?
    By Al Hazz in forum External Engine
    Last Post: 03-27-2009, 07:25 PM
  4. Whats the difference?
    By bevenue in forum Camaro / SS
    Last Post: 10-02-2006, 01:26 PM
  5. whats the difference between a ws6, TA, Z28 &ss
    By blown5.0 in forum General Help
    Last Post: 01-31-2006, 12:19 PM
