06-06-2009, 12:52 AM #1
Whats the difference between these????
Getting ready to order my pushrods and found both of these. What really is the difference? Is it worth the extra $20?
http://cgi.ebay.com/ebaymotors/COMP-...mZ200347787232
http://cgi.ebay.com/ebaymotors/COMP-...1%7C240%3A1318
The stats seem to be the same, just a different description. The come from the same place
┌∩┐(◕_◕)┌∩┐
wouldn't want to fight them!
06-06-2009, 05:43 AM #2Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
They are different part numbers, but I do not see any difference in the specs...call the company and ask for the difference.
06-06-2009, 06:31 AM #3
http://www.compperformancegroupstore...Category_Code=
http://www.compperformancegroupstore...e=GEN3Pushrods
looks like one is a "better" pushrod I guess stronger. But i truely don't know.
Also for the pricing google the ones you want I think you can find a better price
06-06-2009, 11:40 AM #4
They are both chromemoly so both would be strong, I would assume. Either is an upgrade from stock. And either would be good for a street/strip application.
06-06-2009, 12:20 PM #5
Glad to see that everyone else thinks the same as me. I don't see any reason to pay a extra $20 dollars. I will go with the cheaper of the two, both are much stronger then stock so...... I will try googleing.
06-07-2009, 01:49 AM #6Slow'er'Ass
- Thornton, CO
The difference is basicly the name.
Power-forged performance for your racing engine!
COMP Cams Hi-Tech pushrods are power-forged from 4130 chromemoly. Their one-piece design is available in .065 in. or .080 in. wall thickness, and the rods are heat-treated to a minimum hardness of 60 on the Rockwell C scale, for the ultimate in strength. COMP Cams even gives them a black oxide finish, and imprints the length and part number on them.The perfect pushrod for your high performance engine.
COMP Cams Magnum pushrods are the perfect complement to your Hot Street, bracket, oval track, or any other high performance engine. These one-piece Magnum pushrods are made of C1020 high-carbon, .080 in. wall chromemoly steel, and are heat-treated for use with guideplates. They're an affordable way to combat higher spring pressures and the other stresses associated with high performance engines.
06-07-2009, 02:12 AM #7
Thanks Mr. Luos and everyone that replied
Whats the difference?
By kiddynamite in forum Suspension and HandlingReplies: 9Last Post: 02-06-2010, 02:05 PM -
By Sarge in forum Almost Anything GoesReplies: 56Last Post: 10-07-2009, 06:09 PM -
Question: whats the difference?
By Al Hazz in forum External EngineReplies: 1Last Post: 03-27-2009, 07:25 PM -
By bevenue in forum Camaro / SSReplies: 1Last Post: 10-02-2006, 01:26 PM -
whats the difference between a ws6, TA, Z28 &ss
By blown5.0 in forum General HelpReplies: 5Last Post: 01-31-2006, 12:19 PM
