Results 1 to 11 of 11
    Apr 2009
    tn
    lt1 build questions
    I have a 1993 trans-am im building the motor for now. My plans are .30 over with flat tops, better intake, tune and throttle body. already has headers, and flows.
    My first question is
    what kind of cam? didnt see much choices at tsp. was looking at the comp 224/230. would this work? how would it idle.
    and is this gonna kill gas mileage if it idles rough?
    thanks in advance.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    There is very few choices on intakes. Are you going to port the stock heads or go aftermarket? What exactly are you primarily using the car for? Do you have a power goal?
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Have the stock LT1 intake cleaned up. It flows more air than the Edelbrock air gap. Someone did a test and they took a stock untouched intake V's the Air gap and ran them on the same motor with ported and pollished heads. The stock made more power than the air gap. The air gap lost HP and only gained 2 or 3 ftlb torque
    What I do? SHines-IT's Avatar
    Jun 2009
    FL, USA
    2011 Prius
    Quote Originally Posted by JaycenK View Post
    I was told to upgrade to the LT4 intake, is that any better?
    Apr 2009
    tn
    Yes i meant having the stock one opened up for 58mm, main concern is what cam. This is a daily driver and of course want all the power i can get, lol would like a rough idle if it wont kill gas mileage, dont know if that affects it or not. Thats why im asking. thanks in advance
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Lt4 is specific to an lt4 head. The ports on an LT4 and the angle of the intake flange is different. If you have to have it you have to have it.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    your talking about lobe when you say rough idel I belive so what you look at is the LSA on the cam. the smaller the LSA the more lobe it has but there is a point that you really screew up on the cam if you get to much over lap. I can't say I'l let someone else talk cam specs for good preformance with lobe.
    Feb 2006
    Orange County, NY
    always dirty
    Call up a cam manufacturer. When you give them all your info and what you want out of it they can recommend a cam for you. Do you have an auto or M6?
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    +1
    Dec 2013
    redding, california
    1996 trans am
    can anybody recommend whats the best headers as well for 96 lt1 new to this site and basically looking for same thing but im short of what kind of exhaust I should go for
    IIRC you want something like this: LT4 heads
    LT4 Heads | eBay
  1. LQ9 build questions
    By askkmb in forum General Help
    Last Post: 06-22-2012, 09:23 AM
  2. Question: 6.0 build questions
    By onebadws666 in forum Internal Engine
    Last Post: 12-09-2010, 11:31 AM
  3. 02 WS6 build questions
    By MudStainKILLA in forum Firebird / WS6
    Last Post: 04-16-2010, 07:09 PM
  4. Question: LSX Build questions
    By Ls1Bandit02ws6 in forum Internal Engine
    Last Post: 06-26-2009, 07:45 AM
  5. Questions for lq4 build.
    By g-mo in forum Internal Engine
    Last Post: 05-01-2009, 06:41 AM
