Results 1 to 20 of 32
Thread: 02 WS6 build questions
12-06-2009, 02:39 PM #1
i recently purchased a 2002 ws6 an im looking at throwing some more power under the hood. i am looking at getting a new MAF, Throttle body, intake, cam n valve springs, injectors, ported oil pump and headers. I also want ot put in a stall and 3.73 gears. is there anything else that i might need to pay attention to or replace while doing all this?
12-06-2009, 03:03 PM #2
You should consider some head work, or complete replacements. Otherwise you are going to stuff and suck all the extra air through valve ports that weren't designed for it. Good heads will easily add and extra 30 horse to what the cam adds.
12-06-2009, 03:18 PM #3
as far as head work goes it was mentioned to me to do a triple angle valve job and do gasket matching
12-06-2009, 03:22 PM #4
That is basic for any head rebuild, unless they were talking about porting to match the gasket. To do that, you mark the head ports with a metal dye, then scribe the inside of the gasket. You then use a dremel to grind out the material back to the scribe mark. You will still be left with heads that won't flow as well as aftermarket. It might be fine for your build, but you may just want to pick up some LS6 heads used, and get a quick port and polish done.
12-06-2009, 03:55 PM #5
here is the break down of parts i am looking at
92mm FAST intake
92mm FAST big mouth throttle body
Texas Speed Magic Stick 3 cam
FAST 36lb injectors
MAC exhaust headers y pipe n cat back with performance cat
K&N air filter kit
richmond gear 3.73s
B&M transpak
undecided
oil pump? stock or ported?
other fuel system uprades? needed or not?
ingnition upgrades? have msd 8.5mm wires and ngk tr55 plugs
92mm MAF? any good brands?
MR. Kid,
looked into some ls6 heads and texas speed has a pair ported that i can have set up with springs for my cam. How much work goes into mating ls6 heads to an ls1? are they just bolt on or do things need to be taken into effect?
12-06-2009, 04:52 PM #6
12-06-2009, 05:09 PM #7
The oil pump upgrade is a good idea. I may try to port my own. You can also change the spring out to increase pressure.
Upgraded Fuel pumps are also a good idea, but imho, not needed. Check your pressure during tuning, and that will let you know if an upgrade is in order.
LS6 heads are direct bolt on. Those are the heads I'll be adding.
I saw a good write up on spark plug wires somewhere, but can't remember if it was on here or not.
MAf is a good idea to upgrade with the intake. You want the whole intake the same diameter to provide good flow.
Good luck with the build! Post up some pics. See if you can beat me to the dyno
12-06-2009, 05:37 PM #8
the car has 73000 on it so i will prolly get a new oil pump. I also want to freshen up the rings and bearings in the bottom end and re hone the cylinders. Im having trouble finding a 92mm MAF. 85 and 100s are everywhere. ill be ordering parts tues and starting work as soon as they get in so i will def be posting pics soon. THE RACE IS ON!
12-06-2009, 05:41 PM #9
85 is a good upgrade. Every bit helps. Definately a good idea to do a hone, re-ring and bearings. I', hoping my cylinders are good shape so I can just go for a rehone and call it a day. You can see if you're winning by checking here:
http://www.ls1.com/forums/showthread.php?t=123827
12-08-2009, 08:03 AM #10Spaz is My Mentor
Here yeah go:
http://www.ls1.com/forums/showthread.php?t=31657
12-08-2009, 10:03 AM #11
You might wanna consider getting a Trick Flow heads and cam package.
12-08-2009, 12:08 PM #12
I looked into the trick flow packages while i was looking at cams. Have my heart set on
texas speed's magic stick 3. Nice rough idle and the powerband i want. As far as the
heads goes i was going to stick with just some mild head work but now im going to go
with texas speed's ls6 ported heads with PRC double springs. Thanks for the suggestion
though,
12-08-2009, 03:00 PM #13
Aright So here is the final breakdown hopefully,
Complete MAC Exhaust System
TSP Magic Stick v3 Cam
PRC Stage 1 Ported LS6 Heads w/ PRC Double Spring Kit
FAST 92mm Intake
FAST 92mm Big mouth Throttle BodyTurbo
Turbonetics 100mm to 95mm coupler
TSP 100mm MAF Sensor
FTP 104mm Lid
FAST 37lb Injectors
TransGo Shift Kit
Perma Cool 16-18000gvw Tranny Cooler
Precision Ind. Vigilante 2600 stall w/ triple disc lock up
Richmond Gear 3.73s
Flatlander Racing Re-Ring Kit
TSP Ported Oil Pump
MrKid,
My Build up may be on hold till the new year due to scheduling issues for the machine
work in the bottom end. So you may have this one!Last edited by MudStainKILLA; 12-08-2009 at 03:04 PM.
12-08-2009, 03:04 PM #14
Weeeeellllllll, mine is on hold cause I just about broke my finger the other day removing a ground bolt from the back of the head. Smashed it between the air ratchet and the block.
I'll be back at it soon though!
12-08-2009, 03:07 PM #15
damn that sucks man. Hope it isnt to screwed up!
12-08-2009, 03:09 PM #16
12-10-2009, 01:54 PM #17
In lieu of waiting for the shop to reschedule my machining ive been repondering my
intake options. I want to be able to ultilize the whole grille and ram air hood to allow
optimal airflow to a sealed box(when hood is colsed) that contains my air filter. I will be
equipping a 100mm MAF. I have been having some trouble finding an aftermarket
design that fits my application. Does anyone know if ther is one or is this something im
going to have to custom make?
12-10-2009, 02:14 PM #18
I believe the only option you have that comes close to that, is the under car ram air kits that are available. The problem with the grill, is it's only cosmetice for the most part. Your bumper support is behind it, and will block most plumbing in that area. Aftermarket turbo kits usually require you to cut the center of the support and remove it.
12-11-2009, 07:12 PM #19
12-13-2009, 11:09 AM #20
I'm running the stock unit for now, but I will upgrading to a 90 with the new build. The Volant is a great unit, but gets dirty very fast. I live in CT where the roads are sandy year round, so I find that I need to at least bang the filters out ever 1000 miles or so.
lt1 build questions
By dirttrax in forum Internal EngineReplies: 10Last Post: 12-11-2013, 01:32 PM -
LQ9 build questions
By askkmb in forum General HelpReplies: 4Last Post: 06-22-2012, 09:23 AM -
Question: 6.0 build questions
By onebadws666 in forum Internal EngineReplies: 4Last Post: 12-09-2010, 11:31 AM -
Question: LSX Build questions
By Ls1Bandit02ws6 in forum Internal EngineReplies: 40Last Post: 06-26-2009, 07:45 AM -
Questions for lq4 build.
By g-mo in forum Internal EngineReplies: 2Last Post: 05-01-2009, 06:41 AM
